    Extruding a face from a contoured terrain?
    4 Posts 4 Posters 857 Views 4 Watching
      JFraser83
      Im wondering if there is a plugin/tool that allows me to extrude a contoured (non flat) face from a terrain.
      Currently I am using a line extrude command, then copying up the face to that height.
      Or I am intersecting a 'flat' extruded face between to levels of the contoured terrain. These are very time consuming. (hope this makes sense)
      Anything out there?
      • BoxB Offline
        Fredo's Interactive joint push pull.
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=54771#p496773
        • xiombargX Offline
          xiombarg
          Yeah, Fredo's Joint Push Pull for sure. Its a must have plugin.
          If you are doing this a lot and selecting smaller portions of a bigger landscape, you might also want to get better seletion tools, like a lasso tool, to cut down on selection time. Thomthom's Vertex Tools has a nice variety of selection tools.
          • sdmitchS Offline
            sdmitch
            Anything out there?
            Perhaps this plugin?
            404 Not Found
            (sketchucation.com)
            A sample model showing what you start and end with would be most helpful.
            http://sdmitch.blogspot.com/
