    Can't update my SU.
    4 Posts 3 Posters 422 Views 3 Watching
    • john2J Offline
      john2
      Yesterday I downloaded a setup of SketchUp pro 2014 from the official website, because I was getting "a newer version of skechup is available" from some weeks.
      But when I started the installer, it said that if I wanted to repair or remove my sketchup installation, rather than updating it as a full install.
      I checked my sketchup version, but it's an old version and the installer properties say that the latter is newer version. What's going on then?
      • cottyC Offline
        cotty
        The second image shows the actual version number but the first not, did you install different versions in in different folders?
        my SketchUp gallery
        • john2J Offline
          john2
          No, I have only one version of sketchup installed in my laptop which is PRO 2014. I don't even have a 8 or 2013 version installed for plugin issue switch. Then what is causing this problem? πŸ˜•
            The 'About SketchUp' should look like this: Capture.PNG for the latest version of v2014...
            You should be able to Install it in such a way that will update it to be the latest v2014.
            If it's offering a Repair and you choose that route, then can I assume it does not update it to the current version ??
            Your ultimate option is to uninstall your out-of-date v2014, as it offers you: and then re-install it cleanly...
            It will keep any previous licensing files, custom Plugins, Materials, Components, Styles etc, but you will loose all toolbar statuses, dialog setups etc that are Registry dependent...
