    CRASH!!!
    5 Posts 3 Posters 488 Views 3 Watching
    • J
      jerrymich
      When I try to draw an ellipse from the "draw" menu, sketch up crashes. I have tried this many many times. On a couple of occasions, it worked correctly and drew the ellipse. I have tried doing it from guide lines, a rectangle, an offset rectangle and just plain lines. I'm open for suggestions.
      Thanks, Jerry
      • D
        dedmin
        Well, why so little info?!
        SketchUP doesnt have native elipse tool - so, which plugin are you using, what version of SketchUp, OS and etc.!
        We don't have a magic ball to find out all this stuff!
        Help Us to help You!
        • TIGT
          Unless you want to draw thousands... you can use the native tools to draw a Circle and Scale it axially into an ellipse using a rectangular guide ?
          • J
            jerrymich
            Sorry. I am using Windows 7 and sketch up 2014. I just noticed on the plugin compatibility, that it says sketch up 2013. So maybe it won't work with 2014.
            • D
              dedmin
              I have it here - Win 7 64, Su Pro 2014 - with no issues.
              Did you use the SketchUcation PluginStore for installing it?
              The latest version there is 2.0.2
