    Styles wont work Sketchup Pro 2013
    3 Posts 2 Posters 803 Views 2 Watching
      ciano
      I purchased Sketchup Pro for work
      We work on Windows 7 enterprise. The administrator allowed me to install Sketchup.
      Everything works except styles and materials pallettes.
      I have re installed severaltimes, deleting Sketchup directory, but same problem persists.
      the error message says
      Eg “Error Loading File C:\Program Files\Sketchup\SchetchUp2013\Styles\Sketchy Edges\Airbrush with Endpoints.style”
      any help on this is appreciated
      Rob
        The path
        is probably a folder/file which has limited access rights for ordinary users - can your IT guys give you better permissions ?
        Also get them to check that .style and .skm are not being blocked by the firewall - these are in effect .zip files renamed with an alternative filetype suffix, so they might be perceived as a security risk ?
        It is possible to have 'collections' of Styles, Materials and Components in folders within your own 'user' area on your PC, where you have FULL permissions to add/use those files...
        You can link those into SketchUp as custom collections...
        Then you [or IT] could move all of these 'protected' files out of the ' Program FIles' path to your own user equivalent...
        Although, of course each user on that PC would need their own collections setup ?
          ciano
          Hi thanks for this TIG, I'll give it go Monday and report back
          cheers
          Rob
