    Ground plane not coplanar with edges on the x-y plane
    6 Posts 2 Posters 614 Views 2 Watching
    • pbacotP
      Why does the ground plane not line up with an edge that is lined up with the axes? It looks lower than the edge. The distance varies with the distance of the view. If I view from below, it's the opposite--the ground plane looks higher than the edge.
      Just wondering--I guess I don't use the ground plane much and perhaps this is how it has always been. I usually draw my surface in, but I was going to export a quick shot of this for comments and the site plan is in a separate file.
        Just a guess but could it be that you moved the axes at some point? Hide the model so you have clear access to the origin. Right click on the origin and see if Reset is dark. If so, click it.
          That's weird. Is it an OpenGL setting thing? I've never seen the axes not on the ground plane unless the axes have been moved, maybe inadvertently by the user.
          • pbacotP
            Thanks Dave. That apparently isn't it. I guess it just the way it looks.
            • pbacotP
              But when I look from underneath the line looks like it is below the ground plane.
                Any chance you'd share the SKP with me privately? We can see what it looks like on another machine.
