    Retrievin object's absolute height ??
    18 Posts 5 Posters 1.5k Views 5 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i get object's height by
      tra = @main_element.transformation.origin
      reference_height = tra[2]
      but this gives me the vector from the position in space, where the @main_element was created.
      i would like to calculate the height of a defined point (say toppoint of a bbox)
      above absolute sketchup 0,0,0.
      since this is not a transfromation, is there an absolute - z - variable somewhere?
      thanx
      stan
      • jolranJ Offline
        jolran
        array.max
        For a collection of points you could do for ex:
        zmax = pts.map{|p| p.z }.max
          artmusicstudio
          hi and thanx,
          so if understand right,
          this would sort the array of given points and find out the one with the highest z, right? (nice code, btw).
          so if if i had
          pt1=[0,0,5]
          pt2=[0,0,6]
          it would return zmax = 6 , right?
          my problem is, that when i retrieve points WITHIN a group, i get relative coordinates, not absolute. and since the group has no transformation, i again don't get ABSOLUTE coordinates ( with ABSOLUTE i hope to get the Z-zero of sketchup space, independent of, if the user changes the coordinate-origin (axes).
          maybe there is a way to get ABSOLUTE COORDINATES of any point outside or inside of grous/components?
          regards
          stan
            Points within a group are returned relative the the group's origin.
            So let's say you have a point 'pt' at [0,0,1] in the group you don't know where it is in the group's context unless you know where the group is within that let's say it is actually at [11,11,11].
            The group has a transformation: you can apply that to 'pt' and the values will change so:
            pt.transform!(group.transformation) becomes [11,11,12]
            and pt.z is now 12 rather than 1
            Of course your example should also work...
            zz=group.transformation.origin.z
            gives the height of the group so pt.z+zz also gives that height ?
            Of course if objects are nested you need to apply multiple transformations.
              artmusicstudio
              hi tig,
              i understood and made some tests.
              but if i have a group named
              @main_element (i persume it has a transformation, even it is not moved or anything else)
              and say
              i get errors , since my syntax is wrong.
              could you give me the syntax for retrieving the transformation from a group?
              i tried a lot of ways, but always get errors.
              thank you!
              stan
              edit:
              when i define tra as
              tra = @main_element.transformation.to_a
              i get
              tra [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
              how can i interpret the numbers?
              edit 2:
              when i move a group in Z+, tra becomes
              tra [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1968.503937007874, 1.0]
              so 14th position seems to give the height.
              the problem is, that if i create a plane in a certain height (Z+), the transformation counts this as 0,0,0 .
              pos. 14 changes first, when i move the group from its origin place, where it was created.......this transformation is not related to absolute zero.... 😞
              • jolranJ Offline
                jolran
                Does this work ?
                If I resue my code with TIG's recommendations..
                gpz = group.transformation.origin.z
                zmax = pts.map{|p| p.z + gpz }.max
                You could also have a look at Bounds.corner.points and get the highest Z value from those,
                unless you are interested in a particular vertice or so..
                  artmusicstudio
                  hi jolran,
                  1. i'll test your new idea later tonight, but i had the formula with origin
                  already and it gave me the origin of the group at the point, where it was made, not to absolute [0,0,0]. but we shall see !!
                  1. bounding box : i tried this, but i don't need the lowest point of a group, but one special corner within it, so lowest z of the bbox does not help here.
                    and when i retrieve the bbox of the nested element, itz again is relative, not absolute.
                  seems to be tricky somehow....
                  thanx
                  stan
                  • sdmitchS Offline
                    sdmitch
                    @artmusicstudio said:
                    hi tig,
                    and say
                    Yes at the moment the group is created it is given an Identity Transformation.
                    The only reason this would give you syntax errors is if the variable @main_element has not been physically associated with the group.
                    mod = Sketchup.active_model # Open model
                    > ent = mod.entities # All entities in model
                    > sel = mod.selection # Current selection
                    > @main_element = ent.grep(Sketchup;;Group).select{|g| g.name=="@main_element"}[0]
                    > tra = @main_element.transformation; #save the current transformation
                    > @main_element.transform! tra.inverse; # return the group to its created position
                    > zmax = @main_element.bounds.max.z; puts zmax; # get the max z
                    > @main_element.transform! tra; # return the group to its current position
                    thank you!
                    stan
                    edit:
                    i get
                    edit 2:
                    http://sdmitch.blogspot.com/
                      slbaumgartner
                      hi tig,
                      thank you!
                      stan
                      The code block above seems to have been edited out of your earlier post, but sdmitch grabbed it first. It seems to reveal confusion between the name attribute of a group and the symbolic name of a variable that refers to that group. These are separate, unrelated concepts. That is, if you write
                      @foo = ents.add_group #@foo is a variable that refers to a group with no name attribute
                      @foo.name = "@main_element" #@foo now refers to a group with name attribute "@main_element"
                      Following this code, there is no such variable as @main_element. Conversely, there is no group whose name attribute is @foo.
                      Your search above looks for a group whose name attribute is "@main_element". Did you assign that previously using Group#name=, or are you assuming that because you earlier created a group referenced by a variable named @main_element that the group has that as its name attribute (wrong). In any case, you need to test what value was assigned to @main_element by your search. I bet it is nil (because the search found nothing), and that is the cause of your syntax error.
                      Steve
                      • jolranJ Offline
                        jolran
                        I haven't follow along the other discussion so pardon me if butting in..
                        But If your only concern is the get the heighest elements point(?) won't this code work regardless of any transformation made ?
                        %(#FF0000)[bb = group.bounds # could be any element responding to Bounds.
                        cornersZmax = (0..7).collect{|i| bb.corner(i).z }.max]
                        I tested and it seams to be working. ?
                          Since I haven't seen your code...
                          Here's a guess...
                          If your 'reference' is to a 'group' OR a 'component-instance', then it WILL have a 'transformation'.
                          BUT if that 'reference' is to a 'definition' it will NOT ! πŸ˜’
                          puts @main_element.class in your code will tell you what the reference is...
                          • sdmitchS Offline
                            sdmitch
                            What are we trying to determine? If it is the highest point regardless of location and/or orientation or the true height of the group?
                            • jolranJ Offline
                              jolran
                              πŸ˜„
                              I interpreted this as highest point.
                              • sdmitchS Offline
                                sdmitch
                                In that case, ?group?.bounds.max.z should give you that in SU8.
                                  It's possible to devise a group with a transformation where the group.bound.max.z will NOT be a vertex.
                                  If the proposition is to find the highest vertex in a group that is not the same thing ?
                                  However, if you are simply trying to find the max.z it will do...
                                  See this simple illustration...
                                  • jolranJ Offline
                                    jolran
                                    Yeah, that's way simpler...
                                    But as TIG pointed out bbox cp is not always safest way to find highest vertex, so normally one end up traversing the collection anyway.
                                    I'm starting to wonder if TO wants to measure the face height..
                                    to reuse the transformation origin maybe try this.. I guess theres more than 1 way to do this.
                                    targetZ = 0
                                    org = group.transformation.origin
                                    group.entities.to_a.grep(Sketchup;;Edge).each{|edg|
                                        sz = edg.start.position.z
                                        ez = edg.end.position.z
                                        tmax = (sz > ez ? sz ; ez) + org.z
                                        next unless tmax > targetZ
                                         targetZ = tmax
                                    puts targetZ.to_l
                                    • sdmitchS Offline
                                      sdmitch
                                      targetZ = 0
                                      >      targetZ = tmax
                                      > puts targetZ.to_l
                                      Sorry but that only works if there is no rotation. Here is another way
                                      targetZ = 0
                                      tra = group.transformation
                                          sz = edg.start.position.transform(tra).z
                                          ez = edg.end.position.transform(tra).z
                                      	targetZ = [targetZ,sz,ez].max
                                      puts targetZ.to_l
                                      • jolranJ Offline
                                        jolran
                                        Dats true. But I don't understand why you opt to create a new Array for each edge instead of a ternary πŸ˜•
