    Problem with rendering for vray
    renderpluginsextensions
    5 Posts 3 Posters 620 Views 3 Watching
      TobyLarone93
      Hey guys, I'm currently rushing for my submission in 2 weeks. I'm an interior design student and I've occur this error while I was trying to render. When i apply a wall paper on the wall to render, the render becomes a sky looking empty space. I tried painting normal wall paint like white, black etc. the render works normally as it meant to. Please help me out as i'm stressing my soul out of my body
      This is what happened after i applied the wall paper
      this is the wall paper
        rspierenburg
        Notice how all your walls are Purple? This typically means that the reverse face is showing. Rendering software generally doesn't do well with the back of faces. Set your face style to monochrome and reverse all faces that are purple so that only white faces are shown to the camera, then apply your materials to that face only.
        Rob
          TobyLarone93
          Rob
          Thanks Rob. Ah you've saved my butt from this one. Thanks to the info you provided, I actually found another way to solve the problem where I just need to choose the proper side where I could apply the materials on and oriental faces it. THANK YOU!
          Bryan
            TobyLarone93
            Rob
            Hey Rob, apparently the problem is solved with the wall part but not the floor. No matter what face i flip, the render would still go to that sky looking scene. need help asap
            • TedVitale_CGT Offline
              TedVitale_CG
              What version of V-Ray are you working on? There was a similar bug in the initial release of 2.0 that caused this, but it has since been corrected in Service Pack 1 which can be downloaded here: http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
              Ted Vitale
              Owner | Creative Director
              http://www.voxl.vision
