    Fredo Tools
    extensions
    4 Posts 3 Posters 1.0k Views 3 Watching
      antons987
      I downloaded Fredo Tools v 2.0. For the life of me, I cannot locate a single tool, though they were installed from within the Sketchucation Store Plugin. I see all the tools, with .rb extensions under plugin folder, but cannot open them. I am using the latest release of Pro 2014 for PC. The website states they appear, once installed, under Tools.
      They do not. Any help appreciated. Simply trying to use Round Corner...........and an hour later I'm an hour older, and not much else.
      • Jean-FrancoJ Offline
        Jean-Franco
        Round Corner is a specific plugin from Fredo6 which is not part of Fredo Tools v 2.0
        Here you can see the plugins embeded into > http://sketchucation.com/forums/viewtopic.php?p=373073#p373073
        To make it working read the installation instructions.
        For Round Corner look at it there: http://sketchucation.com/forums/viewtopic.php?p=171721#p171721
        Jean-Franco
          antons987
          Hello, thank you for assistance. HOWEVER, it did not work. I went to the advised viewtopic, and attempted both installation methods, i.e. zip and rbz. Neither works. Under my tools menu I see listings for Fredo 6 Collection and Fredo Tools. Round Corner does not appear in either, nor any other menu tem in SketchUp2014. Oddly, when I installed the .rbz file, I was informed the extension was successfully installed. AND, I used the "Find my Plugin Folder" utility to direct me where it should go.
          This is rather frustrating, and I'm not alone with this issue. Why not just cut to the chase and list the apps on the Trimble extension warehouse, where a couple of clicks hands you the goods, period and end of story??? Crazy.
          • TIGT Online
            Have you also installed the latest version of Fredo's "Lib" which is required by most of his tools, and clearly indicated in the tools' guidance notes and their 'Dependencies'...
            It is available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
            or via the PluginsDialog - simple Search for "LibFredo".
            Try that, restart SketchUp to effect the changes... THEN get back in touch if it's still broken... πŸ˜’
