    [Concept]PDF Viewer
    16 Posts 8 Posters 1.2k Views 8 Watching
      I typically have to read from PDFs and I hate swapping between SU and PDF Viewer so I have this little tool.
      It basically loads a javascript based PDF viewer that allows you to load any PDF into the dialog.
      The dialog stays on top of the workspace but you are free to continue to use SU.
      I find it useful...
      A few thumbs or comments and I'll presume you'd like to see it on the PluginStore.
        Aerilius
        Cool! Can you tell more about the difference/advantage whether the window border and window chrome belongs to SketchUp or another application?
        It's still a window and if I didn't want it to occlude SketchUp I would put it side-by-side, no matter whether its SU-owned or another program. Or is it about a pdf viewer with minimal UI?
        And a question that could be of interest: How is the workflow, does it read local pdfs or does it need uploading?
          It is a SketchUp Web Dialog. Nothing groundbreaking I'm afraid.
          It is just a PDF viewer using PDF.js by Mozilla
          Site not found · GitHub Pages
          (mozilla.github.io)
          It allows local file loading from your computer. No uploading.
          I was hunting for something regards making a better local component browser that allowed local file access with thumbnails etc...
          I stumbled on this and hacked it a bit for my own use. Forgot I had it to be honest.
          • BoxB Offline
            Is it something that could perhaps work with Inteloide's Comment Plugin, so you could store the PDF's with the .skp?
              I have no idea as I have not used that plugin yet.
              But anything is possible.
              • BoxB Offline
                Just adding a concept to you concept, and if we both keep one foot on either side of the world we could end up with an immaculate conception.
                  Let's not butt heads
                  • JQLJ Offline
                    JQL
                    And what about linking stuff in model to pdf files and then opening those pdfs with your pdf viewer?
                    This would be useful to get info on special parts of projects that need that extra description.
                    Faces, groups, components...
                    Maybe a tag would appear on that component with a link to the pdf. Turn off the pdf tags layer and you hide them, turn on and you see them.
                    I'm thinking of furniture catalogs, equipment specification, window details, construction documents exported from layout or autocad plotted pdfs, pdfs with rendered images, or reference images from other projects, assembly schemes, you name it!
                    I bet you could also do a nice toolbar with a tag tool and, a tags on and off icon (like for google maps) and the pdf viewer toggle tool.
                    Am I asking too much?
                    It's just because it looks damn nice Rich!
                    João
                    Sorry for such complicated suggestion it's just that I think it would be great...
                    www.casca.pt
                    Visit us on facebook!
                      Yes. Yes you are.
                      But asking is good.
                      • Dan RathbunD Offline
                        Dan Rathbun
                        I and others just used UI.openpanel("*.pdf")
                        and opened a valid return path in the WebDialog.
                        Most users already have AdobeReader installed, so it opens within the WebDialog (unless perhaps the user has the AR properties set to always open outside the browser?)
                        So what would we gain ?
                        The file open UI handling via Js FileSystemObject, instead of SketchUp's Ruby ?
                        I'm not here much anymore.
                        • G Offline
                          glro
                          if the pdf could be embedded into the skp file, the gain wold be big: a model could contain a textual description, for example
                            Jim
                            Cross-platform maybe. There are many "always on top" programs for Windows - is there for Mac also?
                              Dan Rathbun
                              @glro said:
                              ... a model could contain a textual description, for example
                              We can already do that. Every model has a "description" attribute that can be entered via the File tab of the Model Info dialog.
                              It is what is listed in the templates picklist.
                              • G Offline
                                glro
                                yes
                                i never noticed that feature
                                might be useful
                                but very few informations
                                what i meant is adding a calculation note to a scaffolding model, for example; this is typically what i do all the time
                                instead of sending 2 documents, i would send one, te SU model, and the calculation note would be embedded
                                • JClementsJ Offline
                                  JClements
                                  Rich, nice going!
                                  I do like the idea of having links associated with objects in a model which could open any file related to that object (a map, manufacturer's spec, emails, etc.) by any viewer or app already installed on the user's PC. It would be useful in organizing information when reviewing a project with collaborators or when making presentations. The SU file and associated documents could all be stored in a common folder in dropbox, Google drive, etc.
                                  • BoxB Offline
                                    John, Inteloide's Comments plugin will pretty much do what you want.
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56899
