    [Concept]PDF Viewer
    16 Posts 8 Posters 1.1k Views 8 Watching
      It is a SketchUp Web Dialog. Nothing groundbreaking I'm afraid.
      It is just a PDF viewer using PDF.js by Mozilla
      PDF.js - Home
      A general-purpose, web standards-based platform for parsing and rendering PDFs.
      (mozilla.github.io)
      It allows local file loading from your computer. No uploading.
      I was hunting for something regards making a better local component browser that allowed local file access with thumbnails etc...
      I stumbled on this and hacked it a bit for my own use. Forgot I had it to be honest.
      • BoxB Offline
        Is it something that could perhaps work with Inteloide's Comment Plugin, so you could store the PDF's with the .skp?
          I have no idea as I have not used that plugin yet.
          But anything is possible.
          • BoxB Offline
            Just adding a concept to you concept, and if we both keep one foot on either side of the world we could end up with an immaculate conception.
              Let's not butt heads
              • JQLJ Offline
                JQL
                And what about linking stuff in model to pdf files and then opening those pdfs with your pdf viewer?
                This would be useful to get info on special parts of projects that need that extra description.
                Faces, groups, components...
                Maybe a tag would appear on that component with a link to the pdf. Turn off the pdf tags layer and you hide them, turn on and you see them.
                I'm thinking of furniture catalogs, equipment specification, window details, construction documents exported from layout or autocad plotted pdfs, pdfs with rendered images, or reference images from other projects, assembly schemes, you name it!
                I bet you could also do a nice toolbar with a tag tool and, a tags on and off icon (like for google maps) and the pdf viewer toggle tool.
                Am I asking too much?
                It's just because it looks damn nice Rich!
                JoĂŁo
                Sorry for such complicated suggestion it's just that I think it would be great...
                www.casca.pt
                Visit us on facebook!
                  Yes. Yes you are.
                  But asking is good.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    I and others just used UI.openpanel("*.pdf")
                    and opened a valid return path in the WebDialog.
                    Most users already have AdobeReader installed, so it opens within the WebDialog (unless perhaps the user has the AR properties set to always open outside the browser?)
                    So what would we gain ?
                    The file open UI handling via Js FileSystemObject, instead of SketchUp's Ruby ?
                    I'm not here much anymore.
                      glro
                      if the pdf could be embedded into the skp file, the gain wold be big: a model could contain a textual description, for example
                        Jim
                        Cross-platform maybe. There are many "always on top" programs for Windows - is there for Mac also?
                          Dan Rathbun
                          @glro said:
                          ... a model could contain a textual description, for example
                          We can already do that. Every model has a "description" attribute that can be entered via the File tab of the Model Info dialog.
                          It is what is listed in the templates picklist.
                            glro
                            yes
                            i never noticed that feature
                            might be useful
                            but very few informations
                            what i meant is adding a calculation note to a scaffolding model, for example; this is typically what i do all the time
                            instead of sending 2 documents, i would send one, te SU model, and the calculation note would be embedded
                            • JClementsJ Offline
                              JClements
                              Rich, nice going!
                              I do like the idea of having links associated with objects in a model which could open any file related to that object (a map, manufacturer's spec, emails, etc.) by any viewer or app already installed on the user's PC. It would be useful in organizing information when reviewing a project with collaborators or when making presentations. The SU file and associated documents could all be stored in a common folder in dropbox, Google drive, etc.
                              • BoxB Offline
                                John, Inteloide's Comments plugin will pretty much do what you want.
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56899
