Remove Plugin
Silly question: What is the proper way to remove/uninstall a plugin?
It depends. If it is a plugin you got from the Extension Warehouse, you can uninstall it by finding it in the EX and clicking on Uninstall. Or you can go to the Plugins folder and delete the file(s) as needed. You could also just disable it in the SCF Plugin Store if you want to keep it but not have it loaded normally.
Sorry for not responding sooner. In this particular case, it turned out that I had to go to the Control Panel and uninstall it as a program. I had sent the message because I could not find the plugin in the Plugins folder and though maybe I was missing something.
I always appreciate a response.
Register LoginAdvertisement
