RT Engine Bugsplat Problem Vray 2.0 for Skp 2014
Why does bugsplat occur whenever I turn on the RT button? Please help me. Thank you so much!
Any number of reasons could be causing a Bugsplat. Could you elaborate on your issue? What version of V-Ray and SketchUp are you running on? What kind of scene causes the bug splat etc?
i have the same problem, my rt busplats every time even tho i am rendering only a plain box
i use skp2014 and vray 2.0
Again, I can't help unless you give me a little more information to go on. Open Sketchup and go to Plugins> V-Ray> Open Debug Window. What is the full version of V-Ray that you are running "2.00.XXXXX". There is a service release out that fixes a lot of the issues with RT. It could also be an incompatibility with your computer system so specs of the computer are useful see thread: http://sketchucation.com/forums/viewtopic.php?f=322%26amp;t=26019.
The more information you provide, the easier it is for me to help. "RT bug-splats when I render." is not helpful when trying to track down a problem.
