    [Plugin] Centering plugin
    10 Posts 8 Posters 3.7k Views 8 Watching
      Jim
      Made a quick right-click menu for centering selections. (Version 1.0 Available in the Plugins Store)
      The main purpose is centering geometry on a selected Edge or Face.
      There are 3 options:
      Move to origin
      Center on origin
      Center over origin
      Each option acts as expected with Groups and Components.
      When working with non-grouped geometry, all connected geometry is also selected and moved. However, the single selected Face or Edge is used as the object origin, which means you can center the geometry by face or edge.
      http://i.imgur.com/A41D93c.gif
      • cottyC Offline
        cotty
        Thank you.
        my SketchUp gallery
          That's killer
            This one by CPlassais seems also useful! πŸ˜‰
            (in finalization)
              TBoy
              Where is the plugin?
              • PixeroP Offline
                Pixero
                Here is a similar one. But its old and I don't know if it works with current version of SketchUp.
                (www.smustard.com)
                  db11
                  There is also Chris Fullmer's 'Center on Origin' plugin available at the Extension Warehouse:
                  SketchUp Extension Warehouse
                  Your library of custom third-party extensions created to optimize your SketchUp workflow.
                  (extensions.sketchup.com)
                    db11
                    I should note that CLF Center on Origin is missing a 'Center over Origin' option (unfortunately) and only works on Groups / Components β€” not raw geometry.
                      TBoy
                      Yes, "Center over Origin" is the reason to search for Jim's plugin.
                      His page in "PluginStore" is empty.(???)
                        Jim has withdrawn his extensions.
