    Layout png export cuts lines?
    layout
    3 Posts 2 Posters 561 Views 2 Watching
    • K Offline
      kbarbero
      Anyone understand why a png export from LayOut would result in the missing line segments (shown across a horizontal line in the image below)?
      On export, I am selecting 72 resolution since this png is destined for the web. Even at 96 (resolution default for some reason) I still get these lines on the majority of exports - even different sketchup files. It seems to happen across the same location in every image. This shows up in windows preview and adobe photoshop.
        caronte01
        Odd...
        Do you get the same problem exporting to jpeg?
        If so, maybe a style with sketchy edges is being used (just a guess)?
        Can you share the file?
        • K Offline
          kbarbero
          I found out that its exporting 4 different images. The way I discovered this is exporting to PDF then pulling into adobe illustrator, releasing clipping mask and then I see there are 4 images for one image. I rearranged my camera to make the shot fill the entire Sketchup window, then I made the layout frame less than the size of the page in LayOut - this made it all one image. This is a major pain because I have over 100 scenes that exported this way now I have to re-set them up and re-export.
