    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
    • OxerO
      Oxer
      I have created a Spanish Language File with all strings to translate. It's a .txt file that it includes the English string and the corresponding Spanish string:
      "English Text"="Spanish Text"
      The strings are organized by files i.e. main.rb, balise.rb, balise - index.html, ....
      I hope that this file can help you to give support to translate the plugin to all languages.
      http://www.oxervision.blogspot.com/
      • eneroth3E
        eneroth3
        [attachment=0:kyjytomg]<!-- ia0 -->Spanish Language.txt.zip<!-- ia0 -->[/attachment:kyjytomg]
        Thanks πŸ‘ . If I add a language system to the plugin I'll include this πŸ˜„
        My website: http://julia-christina-eneroth.se/
        • OxerO
          Oxer
          It's a pleasure, you are doing a great work with this incredible plugin. πŸ‘
            My translation is perfectly understandable by French people : i have tested it!
            Hundred persons on many forum 😎
            And after some corrections from your advices anybody who read it can use your terrific plugin with great pleasure! β˜€
            It's a quasi copy cat! πŸ˜„
            The story of color text / emulation as my system can't make exactly the same is that we say in French des "Queues de cerises" ! πŸ˜„
            http://2.bp.blogspot.com/-9MeoXNsyt48/T51O1VT5OPI/AAAAAAAABtM/HT30cvyRoNA/s330/cerise%2Bqueue.jpg
            About perfection : that is just a touch of humor πŸ˜„
            PS I even made publicity for your plugin at the Paris Maker Faire this past week-end! β˜€
            Where they where John Bacus and Omar-Pierre Soubra! πŸ˜‰
            This last one said to me (in French πŸ˜„ that your plugin will be put in front on the next Sketchup exibitions everywhere on the world! πŸ˜‰
            • eneroth3E
              eneroth3
              Version 0.1.12 is now published! πŸ˜„
              The main new features are a better interface to save rolling stocks to library and support for translations (big thanks to Oxer for Spanish translation now shipped in the extension πŸ‘ ).
              Download
              The new interface for saving rolling stocks along with the improved documentation has made it easier to add rolling stocks to the library. Now rolling stocks can be saved from within any model instead of having to be alone. Images are also automatically generated now even if it's a bit buggy and a better image can be generated manually (more info in documentation). The new dialog for saving rolling stocks now suggests IDs for them so the user doesn't need to worry to much about that either.
              To save a rolling stocks to library, select it (after it's initialized) and run Ene_Railroad.ss_2_rs_library to open the dialog (graphical interface to open dialog is planned for a later version).
              The translation system allows for translated versions of all strings within the plugin itself. The documentation will however stay in English since it constantly changes.
              You can change between available languages in Plugins > Railroad > Change Language.
              To translate the plugin download the attached file, add the language name and your name at the top 2 lines. The syntax for the translation is "original string"="translated string". When adding the translation remember to look at the string in its context inside the plugin and be consistent with reoccurring terms such as track and rolling stock. Save the file as <language code>.l10n inside the folder "lang/" in the plugin's folder.
              If you want to I can include the translation in the next version πŸ˜„ .
              I hope to see pictures of people's own rolling stocks posted here now πŸ˜„ .
              template.txt
              • OxerO
                Oxer
                Incredible work, all work fine on Mac & SU2014. πŸ‘ πŸ‘
                  Cool new version! β˜€
                  Let see if I will make better this time! πŸ˜„
                  Translation of the text file multi language done! β˜€
                  Must be inserted on the dialog boxes for verification!
                  (because French text is some bigger than English )
                  Tomorrow will be made. πŸ˜„
                  • deaneauD
                    deaneau
                    german language have longer words πŸ˜‰
                    german language is ready
                    dean
                    MADE, BORN AND LIVING IN BERLIN
                    Big Thank You to all Programmers
                    Some German words are so long that they have a perspective. M.Twain
                    • eneroth3E
                      eneroth3
                      dean
                      It already supports Spanish which has short words but a lot of them so I think it'll work πŸ˜‰
                      • M
                        mwm5053
                        Downloaded new ver. and still get empty dialogue boxes.
                        2011 iMac
                        SU 2015 Pro, 2017 Make
                        V2 Twilight
                        macOS Sierra 10.12.5
                        • eneroth3E
                          eneroth3
                          Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
                          • A
                            Aerilius
                            I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
                            • OxerO
                              Oxer
                              I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
                              • M
                                mwm5053
                                Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
                                2011 iMac
                                V2 Twilight
                                • deaneauD
                                  deaneau
                                  _2014.07.02_14h37m22s_005_00836.wmv
                                  now i have my first truck test finished.
                                    Cool but seems wheels don't rotate! πŸ˜‰
                                      All works fine but this box is a little bit smaller!
                                      (and French texts are full inside)
                                        French Interface πŸ˜„
                                        fr.l10n linked
                                        fr.zip
                                        • deaneauD
                                          deaneau
                                          fr.l10n linked
                                          Pilou
                                          look inside your language file. set the punctuation mark at end of the phrase. i have had this forgotten,too.
                                          dean
                                          • deaneauD
                                            deaneau
                                            [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
                                            close sketchup
                                            delete the entry
                                            WebDialog_ene_railroad_drive_train
                                            in the registry
                                            and start sketchup again.
                                            when this will not solve your problem than change the hight etc in the registry.
                                            [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
                                            dean
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 18
                                            • 19
                                            • 8 / 19
