    Plugins Load error
    3 Posts 2 Posters 776 Views 2 Watching
    • C
      Christiantkid
      I am really new in Sketchup.
      Using Sketchup pro 2014 Win 64. I installed two plugins "lightup" and "indigo renderer" but lightup didnt show up in sketchup and indigo load error every time.
      Please help !!!!!
      Lightup files are in same path as shown in folowin.
      Error Loading File C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb
      Error: #<Encoding::ConverterNotFoundError: code converter not found (ASCII-8BIT to UTF-8)>
      C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:7:in require' C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:7:in <top (required)>'
      C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:13:in load' C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:13:in <top (required)>'
      C:/软件/SketchUp pro 2014/Tools/extensions.rb:197:in require' C:/软件/SketchUp pro 2014/Tools/extensions.rb:197:in load'
      C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:19:in register_extension' C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:19:in module:SkIndigo'
      C:/Users/kid/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>'
      • TIGT
        Assuming you have the latest versions... 😕
        Looks like that version of skindigo is not compatible with v2014 ?
        Perhaps lightup might work without skindigo ?
        Disable one and see if the other works ??
        [Temporarily remove one of the tools' RB loader files]
        You need to PM/email the tools' authors otherwise.. 😒
        • C
          Christiantkid
          @TIG
          Thank you
          I ll try what u said I m sure the skindigo is not compatible with v2014
          And another question,
          I installed IRender nxt and could use it but everytime I try to render it my computer shut down, is that my model too big or my computer too sucks
