    [Plugin] InfinitePanOrbit [Now on OSX]
    38 Posts 14 Posters 19.3k Views 14 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Download in the PluginStore
      Releases the Pan and Orbit tools from the screen boundaries. When using these tools, if the cursor reaches the screen edge, it is teleported to the other side. So you can pan and orbit indefinitly.
      You can toggle the plugin in "View > InfinitePanOrbit"
      OSX support by John "Driven" Boundy
      Known issues:
      • The view flashes sometimes. The "flash" can be really long (sometimes up to 1 sec) and annoying in complex models. In that case, you should disable it.
      • KrisidiousK Offline
        Krisidious
        Very kool Jiminy...
        By: Kristoff Rand
          Cool idea.
          I installed it on my Win 7 machine from the PluginStore and it worked with the blank drawing window that was open before installing but I opened a model file and tried it. It didn't work. I've tried closing and reopening SketchUp several times. No change. 😞
          • BoxB Offline
            A handy little tool, almost works for me.
            It will orbit top and bottom and to the left side but going to the right it hits a wall.
            I'm currently on a single display setup but there would normally be one or two other screens off to the right side, perhaps that is causing it.
            • ludnidL Offline
              ludnid
              Awesome. Just Awesome.
              If you don't ask, the answer will always be no.
                jiminy-billy-bob
                Indeed... I'll fix it.
                You're right, it's probably related to that. Although, I don't get why.
                What does this window show you?
                http://i.imgur.com/HMmLM.png
                • JQLJ Offline
                  JQL
                  Jiminy, I'm also on single display and it's not working to the right too.
                  EDIT: I use a projector on this PC sometimes though. Those screens display the following:
                  www.casca.pt
                  Visit us on facebook!
                    jiminy-billy-bob
                    New version 1.0.1
                    Changelog :
                    • The plugin now works with models created or opened after SU startup
                    • It should now trigger correctly on all screen borders
                    Download in the plugin store !
                      Thanks JBB. I'll give it a try when I get home after work.
                      • CadFatherC Offline
                        CadFather
                        Thanks JBB - Pure Zen ! 😎
                        • BoxB Offline
                          Thanks JBB works perfectly now.
                          • JQLJ Offline
                            JQL
                            I'm getting used to this really fast... Thanks!
                            www.casca.pt
                              Works perfectly for me now. Even with a second display. Only problem is my mouse pad isn't big enough. πŸ˜†
                              • BoxB Offline
                                When the discussion about this plugin started I thought, hmm, interesting idea but don't think I would use it much. Then when you released the plugin I thought, Ok I'll try it but I hope he's made it easy to turn off as I'm certain I'll only use it occasionally.
                                Now that I have it and have used it for a day or so I can't think why I would turn it off and don't understand why it isn't a normal feature. Bloody Brilliant, thanks again.
                                • O Offline
                                  othmanalazzam
                                  Wow, that what was I waiting for ^_^
                                  • O Offline
                                    othmanalazzam
                                    it's running smoothly in your video (on your machine) but it doesn't in my sketchup.. when it reaches the edge, it goes reverse and the go forward.. I hope you can try it on another machine please, or try to add more plugins in the Main UserInterface to your sketchup and test it again.
                                    thanks.
                                    • O Offline
                                      othmanalazzam
                                      what happened with me (each time I switch over the edge) is actually similar to what happened at 0:35 in your video.
                                        jiminy-billy-bob
                                        Yes, this is what I meant by:
                                        @jiminy-billy-bob said:
                                        Known issues:
                                        The length of this "flash" is heavily dependent on the model's complexity. The more complex the model, the more you're gonna experience this issue. For now, I can only advise you to disable it when working on heavy models.
                                        I found a solution, but it resets the center of rotation. And as you know, the center of rotation depends on the location of the mouse when you activate the pan/orbit tool. So this leads to some really weird things depending on the geometry configuration in the view.
                                        I don't think this is a good solution...
                                        I'll keep searching for a solution.
                                          The Orbit tool does it naturally sometimes, too.
                                            jiminy-billy-bob
                                            New version 1.0.2
                                            It now works on OSX.
                                            You should all thank Driven for this!
                                            Changelog :
                                            • OSX support
                                            • 1 / 2
