    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Urgent help....my vray render is blank result like a sky
    renderpluginsextensions
    5 Posts 4 Posters 6.0k Views 4 Watching
    • Z Offline
      zach007
      Hi....my name is zach...i am a sketchup 2014 and vray user. I have a problem with my vray when starting to render...when i clicked render, the result is blank blue like the sky in the mid day...Hi expert, would you please help me how to fix this? Appreciate for your kind help...thank you
        rspierenburg
        Just to let you know, posting the same post in two forums is considered bad form. As I mentioned in the other thread we need to know at minimum what version of Vray you are using. Because that sounds like a bug that occurred in an earlier version.
        Rob
          rully007
          Hi...sorry for that...I face when rendered it resulted blue sky picture with below results:
          Preparing renderer...
          Preparing scene for rendering...
          [RenderView] startCameraTime=0.000000, endCameraTime=0.033333
          [RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
          Creating bitmap manager
          Initializing built-in VFB.
          Preparing camera sampler.
          Preparing scene for frame...
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/29d86071805d8b81c68529ddff153a1c.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/93fa96568037e6ef97c1ebb43ed524bc.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/3194050e9b8ce9954ff339a902482857.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/186a82a57870640ee78f3c5346cc0171.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/3ffbfe0bde593cc7545bf7afa8f95c0e.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/1497380b79fc7953f6b1d5ed10ffe822.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d586341c8589f34aef6b4c58258975dd.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d71b2392815e203947f4330db3cd85f5.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/e81f9818f47d715fe00573753b5ab045.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/f6db4f3d223b435f665c75f09224d2b6.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/967cdf3bcffe76d31ba6292c794dd40c.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/fe1dfa899b50122955739ab922c0e0be.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d63939a69cfba929504522c9e7c3ed45.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/37335e3e23ee31b252eca01e3748c085.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d28ab37b7d3503d08077a72d495418a2.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/9c88edfcd9822223f0db55d63bcad033.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/29e571f30ccafc7a28067eea02b12e80.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/ddfb9be45bd6e621312aa73db435d163.jpg" loaded.
          Bitmap file "C:\Users\USER\Documents\Formica_180FX_3421_BiancaLuna.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/670f68ce0970baeb829ab9519a126f59.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/0c96fdf0e3309bec1aa823b5d80bdf55.jpg" loaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/a7e570c210fd305f84e412c844535fd2.jpg" loaded.
          Bitmap file "C:\Users\USER\AppData\Local\Temp\ChaosGroupTextureCache\a69b8316e3ed364d35b5dd9efb5f02de.jpg" loaded.
          Compiling geometry...
          Preparing ray server.
          Creating and initializing 2 thread(s).
          Allocating memory for build data of 2894620 faces (11578480 bytes, 11.0 MB).
          Initializing face build data.
          Creating 'done' event.
          Starting first thread.
          Waiting for thread completion.
          Releasing thread resources.
          Scene is empty.
          Preparing direct light manager.
          Preparing global light manager.
          Irradiance sample size is 84 bytes
          Photon size is 56 bytes.
          Light cache sample size is 120 bytes.
          Building light cache.
          Tracing 640000 image samples for light cache in 2 passes.
          Setting up 2 thread(s)
          Light cache time interval is (0.000000, 0.000000)
          Threads completed
          Merging light cache passes.
          Light cache contains 0 samples.
          Light cache samples collected; compiling lookup tree.
          Prefiltering light cache.
          1 interpolation maps registered
          Rendering interpolation maps with minRate=-3 and maxRate=-2
          Threads completed
          Threads completed
          Calling endPass() on irradiance maps
          Calling prePassDone() on irradiance maps
          Image prepass completed.
          Rendering image.
          Threads completed
          Number of raycasts: 870055
          Camera rays: 870055
          Shadow rays: 0
          GI rays: 0
          Reflection rays: 0
          Refraction rays: 0
          Unshaded rays: 0
          Clearing global light manager.
          Clearing direct light manager.
          Clearing ray server.
          Clearing geometry.
          Number of intersectable primitives: 2894620
          SD triangles: 2894620
          MB triangles: 0
          Static primitives: 0
          Moving primitives: 0
          Infinite primitives: 0
          Clearing camera image sampler.
          Clearing camera sampler.
          Clearing DMC sampler.
          Clearing path sampler.
          Clearing color mapper.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/29d86071805d8b81c68529ddff153a1c.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/93fa96568037e6ef97c1ebb43ed524bc.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/3194050e9b8ce9954ff339a902482857.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/186a82a57870640ee78f3c5346cc0171.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/1497380b79fc7953f6b1d5ed10ffe822.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/3ffbfe0bde593cc7545bf7afa8f95c0e.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d71b2392815e203947f4330db3cd85f5.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/e81f9818f47d715fe00573753b5ab045.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/967cdf3bcffe76d31ba6292c794dd40c.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/fe1dfa899b50122955739ab922c0e0be.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d63939a69cfba929504522c9e7c3ed45.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/37335e3e23ee31b252eca01e3748c085.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d28ab37b7d3503d08077a72d495418a2.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/9c88edfcd9822223f0db55d63bcad033.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/29e571f30ccafc7a28067eea02b12e80.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/ddfb9be45bd6e621312aa73db435d163.jpg" unloaded.
          Bitmap file "C:\Users\USER\Documents\Formica_180FX_3421_BiancaLuna.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/d586341c8589f34aef6b4c58258975dd.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/670f68ce0970baeb829ab9519a126f59.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/0c96fdf0e3309bec1aa823b5d80bdf55.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/a7e570c210fd305f84e412c844535fd2.jpg" unloaded.
          Bitmap file "C:/Users/USER/AppData/Local/Temp/ChaosGroupTextureCache/f6db4f3d223b435f665c75f09224d2b6.jpg" unloaded.
          Bitmap file "C:\Users\USER\AppData\Local\Temp\ChaosGroupTextureCache\a69b8316e3ed364d35b5dd9efb5f02de.jpg" unloaded.
          Cleaning up bitmap manager
          I use Sketchup Pro 2014 and Vray 2.00.24261....please need your support how to fix this πŸ˜„
          Thank you for your kind help....
          Regards,
          Zach
          • V Offline
            valerostudio
            Sounds like you have an older version that has the missing texture bug. Earlier beta versions of 1.6 was doing this when it couldn't find an associated map for a VR texture. I would update to the latest 2.0 or try regenerating v-ray materials from the debugging menu of V-Ray.
            • Z Offline
              zach007
              Hi...thanks for reply..i think i have the latest version....or how to update vray pls? I have already re debuging vrqy material but still blank result after rendering like a blue sky...please advice
