    When rendering....
    renderpluginsextensions
    2 Posts 2 Posters 346 Views 2 Watching
      boyze
      Firstly I'd just like to say hi as I'm new to the forum and have found many solutions to my problems here so big thumbs up for that.
      now for my query. (Lets hope I can explain this right)
      I'm working on a scene and was wondering if there was a plugin of some sorts that I could use in conjunction with Vray to show a visual guide of what will appear in the render output. Something like a dashed line rectangle to the size of the desired output size so I don't have to keep re-rendering if something is just out of shot.
      I hope I've explained it will enough but if needed ill photoshop an example of what I mean.
      • V Offline
        valerostudio
        If you match your viewport ration in V-Ray, then what you see in SU will always be what comes out of V-Ray. If you want to customize the ratio, for example, you what a true 16:9 proportion, then you can use ThomThoms V-Ray Toys plugin.
        http://sketchucation.com/forums/viewtopic.php?t=15491
