    Help with Render and Line Drawing not matching upp
    renderpluginsextensions
    2 Posts 2 Posters 448 Views 2 Watching
    • H Offline
      hotdog22
      Hey guys, ive been kinda stuck for a few good hours now trying to sort this matter, im currently using vray to render elevations (im an architecture student hehe) and i normally add the Line drawing on top of it and scale the image on Photoshop to fit the line drawing,
      but the proportions of the image dont seem to match the line drawing which was exported to scale (1:200) 😞(
      i have already checked the output options on vray and it says match viewport and so i havnt adjusted anything there... its also on parallel projection as well...
      Any tips am i doing anything wrong?
      im using vray 2.0 and sketchup 2013 pro.
      Thank you guys in advance
      regards
      Hotdog22
      • TedVitale_CGT Offline
        TedVitale_CG
        Could you share the file? I'd be interested to see how you are going about creating the elevation.
        What I think may be happening is the exported 1:200 elevation have a different resolution than the rendering. Have you tried just exporting the un-scaled scene from SketchUp at the same pixel resolution as the rendering and composite those two? Then you can re-scale the rendered elevation in Photoshop based on the 1:200 elevation you've already exported.
        I think SketchUp takes some liberty when it exports a scaled drawing so there may be some discrepancy between the scaled view and the rendered view. Let me know what you come up with, and I'd love to see the final result. But again, if you still have trouble with it, post the scene here or send it to me directly, and I can give you some more direction on how to best solve this.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
