    Cannot get Default Material Back on Faces
    3 Posts 2 Posters 1.2k Views 2 Watching
    • Mistro11M Offline
      Mistro11
      Using SU 2014 Pro:
      By mistake I colored a model from the group level and all faces that had default material was colored with dark grey. When I try to put the faces back to default color, nothing is happening. Even when I go in and select a face directly, the dark grey will not change. Any help is appreciated.
      Edit: The reason I want to get back to default is to make sure I know where the back faces are before I export to render.
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
      • cottyC Offline
        cotty
        How did you try? With this:
        For this, you can switch to monochrome view.
        my SketchUp gallery
        • Mistro11M Offline
          Mistro11
          Thanks Cotty. I did try changing the face styles. The style of the model did change but not for what was already colored. I made a model outside the group and the default colors applied. But I don't understand why I cannot paint the default color back to the colored surfaces. I did it before plenty of times. Sometimes it is necessary when working with the UV plugins.
          I will try and remember about the monochrome view. Thanks again.
