    SketchUp 2014 crashing more than ever
    2 Posts 2 Posters 302 Views 2 Watching
    • M
      mathieuweekes1
      Since buying a new 15" Macbook, upgrading to SU2014 and the latest version of Shader light, SU is crashing all the time?
      The plugins I use are:
      Bezier Curves
      Chamfer Along Path
      Set Centre Point
      Drop GC
      Stray Lines
      Weld
      Can anyone advise me on how I go about trying to prevent these frequent crashes?
      Should I remove these plugins? Or is there something else I can try?
      SketchUp is unusable at the moment...the slightest task and it gives up the ghost....
      Any help will be welcomely received...
      MW
      • D
        driven
        are all your plugins the latest version?
        v2014 uses Ruby 2, ANY old plugins may break...
        if they are all fresh downloads with v2014 compatibility, on a mac the first suspect will be a renderer. [any breed]
        john
