    Help please
    3 Posts 3 Posters 219 Views 3 Watching
    • L
      leijnse
      Hello
      Hello my name is Jeroen Leijnse, I am now a week confesses with sketchup, with the reason that I want to start for myself and can provide quite a bit of information through sketschup. Now I'm almost done with the project only stunned on a problem, the lines of each object is seen to through the walls, this I want to have again as before.
      Best regards, Jeroen Leijnse
      http://i57.tinypic.com/23jizv5.jpg
      • BoxB
        Go View/Edge style untick back edges.
        Or if you haven't changed the shortcut hit k on the keyboard.
        Best to update your profile also as you have it set as SU7 while you screenshot is from SU2014.
        • TIGT
          BVox beat me !
          Look at the Style set for the view.
          Edit it... 'Edge Settings'...
          It probably has 'Back Edges' ticked ?
          Un-tick that.
          Also un-tick 'Extensions' and 'Endpoints' if they are set too...
          Also, if you have not given external-walls a proper thickness then that can also lead to edges bleeding through...
