    Controlling the stamp tool
    3 Posts 2 Posters 547 Views 2 Watching
    • U Offline
      unearthed
      When using the stamp tool I always find problems setting the level of the final surface position - is there some (unknown to me) way of controlling position using a key combination? The little up/down pair of arrows that come up always look so enticing but no amount of keying does anything...
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
        Draw some guides or geometry off to one side at your desired z-height for the 'stamp'.
        Make the stamp, approximating the z-height to that 'guide'.
        Then edit the group containing the newly stamped form.
        Select the stamped 'flat' footprint face[s].
        Activate the Move tool...
        With Shift held to constrain movement in the blue z-axis, snap to the guide/geom.
        The flat parts will now be accurately located at that z-height.
        • U Offline
          unearthed
          Thanks TIG, that worked perfectly.
