    How to save a group/component and use it again in?
    2 Posts 2 Posters 1.4k Views 2 Watching
      Shadowbluff
      So, how does one do this so they can be used again in another project? Is it possible?
      Thanks!
        You can use Edit>Copy and Edit>Paste or PasteInPlace on anything in one SKP and thereby duplicate it in another SKP.
        You can't readily reuse a Group in another SKP later on, unless you convert it to a Component [context-menu item]...
        The usual way to make one SKP's Components available for use at any time later, is to open the Component Browser and either Save an individual Component [you can also do this for a selected instance, from a context-menu item] or you can choose the flyout menu option to Save all of your Components to a Collection.
        You can delete any unwanted SKPs from that folder...
        That Collection [aka Library] can be made accessible from the Component Browser, so that you can use those Components in future projects...
        If you are thinking of keeping all of your Component SKPs in a single location then ensure you have FULL Security permissions to that folder - the standard SketchUp/Components folder might have limited permissions by default...
