    Slope analysis of 2d Autocad contour drawing
    23 Posts 7 Posters 5.8k Views 7 Watching
    • john2J
      john2
      Hello everyone
      I have an autocad file of site plan having contours. It is all in 2D form. A flat drawing with all the contours and labelled with their levels.
      I want to do a slope analysis
      like
      Shade areas with slope of
      5-10%
      10-15%
      15-20%
      above 20%
      How can I do it?
      I will have to make a model of that drawing in sketchup with sandbox and then do something. ?
      Can anyone give a full workaround of how to deal with such things?
      • KrisidiousK
        Krisidious
        This will get you halfway there... http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52039
        Then someone else will tell you about the color height map... i can't remember what the name of it is.
        By: Kristoff Rand
        • JQLJ
          JQL
          There's a color by slope plugin somewhere in here
          www.casca.pt
          Visit us on facebook!
          • KrisidiousK
            Krisidious
            I know... and I can't find it for the life of me.
            By: Kristoff Rand
            • jeff hammondJ
              jeff hammond
              %(#FF0000)[__c
              ___o
              ____l
              _____o
              ______r]
              _______by slope is a plugin by chris fullmer:
              404 Not Found
              (sketchucation.com)
              (it's available via the trimble extension warehouse)
              ..or maybe try this one by sdmitch:
              404 Not Found
              (sketchucation.com)
              dotdotdot
              • KrisidiousK
                Krisidious
                AHHHH Thanks Jeff.
                By: Kristoff Rand
                • john2J
                  john2
                  Thank you everyone for replying. I'll download these plugins for sure. πŸ˜„ These plugins are for the situation wherein the terrain model has already been made. As i have mentioned before, my drawing is flat 2d drawing. So if i import that in sketchup, it comes in x-y plane only. There is no z axis location of object in that drawing (all z axis position is 0). So is there a quick way to make the model of that drawing or will I have to place one by one each polyline to the desired level?
                  • KrisidiousK
                    Krisidious
                    No, use that toposhaper I linked... That will build your topo.
                    By: Kristoff Rand
                    • jeff hammondJ
                      jeff hammond
                      watch the video 'altitude editor' in the first post of the TopoShaper thread that Kris linked to..
                      you do have to set the lines to height- it's just that there are some easier ways to do it with toposhaper besides selecting each one then move it vertically then select the next and so_on_and_so_forth
                      dotdotdot
                      • john2J
                        john2
                        I have made my terrain but couldn't do my thing
                        I want slope analysis like this 0-5% ------ very light brown
                        5-10% -----little dark brown
                        10-15% ---more dark brown
                        and so on till 25% and above ----- darkest brown
                        Chris fullmer plugin does this by itself not lettingme put values.
                        • KrisidiousK
                          Krisidious
                          Perhaps you could use Photoshop or Gimp to replace colors?
                          Oh wait. It's not letting you dictate certain slopes. just it's own determination huh? I think this is going to be something that doesn't exist.
                          By: Kristoff Rand
                          • KrisidiousK
                            Krisidious
                            You can make a new post in the Plugins forum here. http://sketchucation.com/forums/viewforum.php?f=323
                            Title it [REQ] Slope Analysis and then describe what you are wanting it to do very specifically. There are many developers and if this interests them they'll make it. Or they might tell you how to make it or how it can be accomplished.
                            By: Kristoff Rand
                            • jeff hammondJ
                              jeff hammond
                              if you read through the color by slope thread, you'll see that TIG has written the code to get the desired function.. it hasn't been added to the published version though..
                              i'm going to assume neither chris nor tig are going to combine it or else it would of been done already.. most of the requests in the thread were to have the functionality which tig addressed.
                              basically, someone with some ruby knowledge will have to explain (in simple terms) how to add tig's code to color by slope..
                              (i just tried and failed miserably.. πŸ˜† )
                              dotdotdot
                              • john2J
                                john2
                                Yes, it is determining by itself. Auto mode, i just enter rgb values and it does the thing by itself.
                                • TIGT
                                  I've PM's you an adjusted version of Chris's RB that should do what you want...
                                  • KrisidiousK
                                    Krisidious
                                    Oh do share Tig...
                                    By: Kristoff Rand
                                    • KrisidiousK
                                      Krisidious
                                      Oh it's Chris' plugin adjusted... I understand. 😞
                                      By: Kristoff Rand
                                      • john2J
                                        john2
                                        Thanks a lot!
                                        There's one little problem.
                                        I made the terrain using topo plugin of fredo. The faces that i colour using modified plugin are coming in ugly triangular fashion. What can i do to make the colour smoother?
                                        • TIGT
                                          You can't. πŸ˜•
                                          The facets are individually colored depending on their slope %.
                                          If you make a more subdivided mesh [with finer settings or using say Artisan to post-process it ?] the facets will get smaller... but they'll always be small triangles of a single color, no matter how small they get.
                                          You don't want to go too fine as the extra geometry will slow down SketchUp significantly...
                                          There is way of using a 'projected' graduated textured material initially on a large vertical face to show faces of differing heights smoothly transitioning - from dark to light say - on a terrain mesh.
                                          https://3dwarehouse.sketchup.com/model.html?redirect=1%26amp;mid=77627ea5941ff3d387ecd6083924dba
                                          http://sketchucation.com/forums/viewtopic.php?p=149747#p149747
                                          But if you think about it a little... you can't do the same with 'sloped' facets because those can occur anywhere in 'elevation'...
                                          How could you ever get the right effect between two adjacent slopes which could be at any other slope compared to the first one you considered ? Also every triangle would usually have three neighbors each needing a different transitional graded color/texture and then those in turn etc...
                                          • john2J
                                            john2
                                            Okay, so what is the most visually cleanest way to do this?
                                            Subdividing with Artisan only or any other free alternative?
                                            And I'd like to thank everyone who guided me to this stage.
                                            I've visited this forum after a really long time and getting a specially customized plugin messages to me, simply blew my mind away.
                                            Thank you TIG sir and everyone
                                            • 1 / 2
