    Photo texture vs. v-ray render
    renderpluginsextensions
    5 Posts 3 Posters 1.1k Views 3 Watching
    • K
      Kittyarch
      could You pls help me:
      i select the "Add Photo texture" to a surface, and use grab to add the selected area.
      In the SU screen its ok, but when i make a render (v-ray engine), its wrong, distort.
      (square area into 2 triangles)
      What should i do, make the render image the same like in SU screen? (without distortion)
      • 3dita3
        3dita
        I think this is a known bug. Try exporting the model in 3ds exporting also textures. At that point when you reimport the textures, the images should be fine!
        3dita - Digital Visual Motion
        • K
          Kittyarch
          export to 3ds is ok.
          Can u write this texture import step by step?
          (what i tried it doesn't work)
          Thx!
          • andybotA
            andybot
            does it work if you do "make unique texture" for that face? (Instead of exporting to 3ds, etc.)
            • K
              Kittyarch
              yes thx, 'make unique texture' is works now πŸ‘
