    Photo texture vs. v-ray render
    renderpluginsextensions
    5 Posts 3 Posters 1.0k Views 3 Watching
      Kittyarch
      could You pls help me:
      i select the "Add Photo texture" to a surface, and use grab to add the selected area.
      In the SU screen its ok, but when i make a render (v-ray engine), its wrong, distort.
      (square area into 2 triangles)
      What should i do, make the render image the same like in SU screen? (without distortion)
      • 3dita3 Offline
        3dita
        I think this is a known bug. Try exporting the model in 3ds exporting also textures. At that point when you reimport the textures, the images should be fine!
        3dita - Digital Visual Motion
          Kittyarch
          export to 3ds is ok.
          Can u write this texture import step by step?
          (what i tried it doesn't work)
          Thx!
          • andybotA Offline
            andybot
            does it work if you do "make unique texture" for that face? (Instead of exporting to 3ds, etc.)
              Kittyarch
              yes thx, 'make unique texture' is works now πŸ‘
