    How can i make my material independent of light
    renderpluginsextensions
    3 Posts 2 Posters 386 Views 2 Watching
      sketchuh
      i want to make super white shiny material. but the light i set up made the white material bit yellow or dark. how can i make my material independent and the light settings?
      2nd question is , how can i make my glass not dark. i set all the color white, but the glass still look dark.
      thanks in advance.
      the shiny material is set pure white, but it turned out to be yellowish.
      • andybotA Offline
        andybot
        Increase your lighting levels (or camera exposure).
        How your material appears has nothing to do with how white you make something. In fact, if you use a material that is too white, you'll get inaccurate calculations from vray. Also, learn to use Photoshop or Gimp and adjust your colors in postprocessing.
          sketchuh
          thanks. i fixed it in photoshop.
