    Render improperly processed?
    renderpluginsextensions
    4 Posts 2 Posters 410 Views 2 Watching
    • ALJr97A Offline
      ALJr97
      Yesterday I finished my project in the Sketchup. I configured the V-ray to render with the sunlight that comes through the window. when the rendering finished the result was not good. 😢 see it :
      http://imageshack.com/a/img513/5051/v7el.png
      My question is : Why the sunlight was not well rendered in the reflection of the wall and of the TV ?
      • V Offline
        valerostudio
        If you are using 2.0, my first recommendation is to try one of the interior presets. Try the High Quality or Very High Quality. Your render times will be longer, but longer renders equal cleaner renders.
        • ALJr97A Offline
          ALJr97
          please. Can you tell me how do I it ?
          • V Offline
            valerostudio
            Sorry to sound crass, but if you need help loading a preset, then you really need to look at the manual and some tutorials. V-Ray is not a magic rendering engine. You will never have clean noise-less renders if you don't learn the parameters of the engine and understand them clearly.
            If you are using 2.0, then this is how you load a preset.
            http://help.chaosgroup.com/vray/help/sketchup/150PB/tutorials_preset.htm
            Bookmark this page and reference it... a lot.
