    2013 / 2014 custom shortcuts
    8 Posts 4 Posters 637 Views 4 Watching
    • greenskpG Offline
      greenskp
      In previous versions of sketchup, my shortcut to toolbar Layer was Alt + L but in 2013 and 2014 versions i am not able to assign shortcut.
      It's possible create shortcuts to toolbars and custom toolbars? How?
        Jim
        Not natively, but a plugin could be made to add the toolbar names to a menu, and then you could assign shortcuts to the menu items.
        Like this plugin, for example.
        old_toolbar_menu[jf].rb
        • greenskpG Offline
          greenskp
          Hi Jim!
          It's possible assign shortcut, for example, for roundcorners toolbar?
          I have to edit ruby file?
            @greenskp said:
            Hi Jim!
            You do NOT need to edit anything.
            Use the SketchUp menu's [Window} Preferences > Shortcuts
            In the 'filter' enter part of the menu name you are looking to shortcut to - e.g. Round...
            and you get a reduced list, select the appropriate menu item and assign a key or key-combo of your choice, if it would overwrite an existing key you are warned...
            If a tool is context-sensitive - e.g. Texture, Reverse Faces, Orient Faces etc - you need to have something selected that would put that item in the context-menu - e.g. in the examples above a 'Face' - then it will appear in the filtered list when you open the Preferences > Shortcuts...
            • greenskpG Offline
              greenskp
              Hi TIG
              I like enable and disable toolbars all the time, use shortcut and choose some of the options available .
              As you have mentioned, i will have many shortcuts and i need just one.
              Roundcorner is just one example, i could use Bezier_Toolbar which has many options.
                You cannot [or at least should not!] change shortcuts in Ruby code.
                I fail to see what the issue is here.
                There are plenty of keys available [A-Z,0-9,F1-F12 etc]and when combined with shift/ctrl/alt make more that enough for most users πŸ˜’
                • BoxB Offline
                  I think he wants a shortcut for the toolbar not the tool.
                    Well, he can't have it ! πŸ˜‰
                    Toolbar states are not shortcut-able.
                    He could write a script to toggle the toolbar on/off and then shortcut to that script's entry in a menu...
                    But he needs to find the toolbar to do that...
                    There are a few better methods for v2014, but it's still not easy...
