    [Plugin] AttributeInspector 1.1.1 – 2014-05-08
    45 Posts 10 Posters 3.2k Views 10 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Another think that throws me off a bit, is that I am used to the +/- buttons being on the top toolbar, in the Scenes and Layers managers.
      BUT.. I like it, mainly because I myself thought about doing this, but never had the time to do much more that the simple lister pluglet for the GeoLocation dictionary.
      I'm not here much anymore.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        @dan rathbun said:
        Sketchup::Model#typename() is added into the API by "dcutils.rbs"... so turn the DynamicComponents extension back on, and you will no longer have the errors.
        Thanks!
          Aerilius
          The bug has been fixed some time ago in the (not yet released) next version. I'll publish it soon.
            Dan Rathbun
            v1.0.1
            When I choose "materials", nothing happens. (I should see a blank list when no dictionaries are attached to any material in the model.)
            Should materials not having dictionary attached be displayed but grayed out ?
              Dan Rathbun
              Clicking (giving focus to) the edit boxes in the righthand pane, cause the row height to increase (by differing amounts, depending on whether the attribute name or value box gets focus.)
              • genma saotomeG Offline
                genma saotome
                Hi Dan, would it be possible to expand upon this idea and code up something that will find all elements that match an attribute value? AFAIK there isn't a way to find faces that have no materials applied... and I have a plug-in I use all of the time that makes use of the dictionary to hold an assigned value (always about faces) but if I decide to change that value I have no way to tracking down all instances except by recollection and/or trial and error. So being able to do this attribute --> this value --> show me all that match would be very handy for me. By "show" it would be adequate to show the attribute information but I think it would be better to select them instead.
                I think anyone else who uses the dictionary feature might also benefit because those data are not part of SU's own selection function and your plug-in, as it is now, does reveal that data. I think taking the next step and figuring out how to do a select based on Dictionary attributes and their values would be a big plus.
                Thank you for any consideration you give this.
                  Dan Rathbun
                  ThomThom's SelectionToys plugin can modify your selection set by many filters.
                  There are at least 4 filters regarding add or remove objects according to front/back material set as default ( nil.)
                  So first you window select a bunch of objects. Then use the SelectionToys face filter, so only faces remain in the set.
                  Then use the default material filter for front faces, and/or back faces.
                  Install manually via
                  http://extensions.sketchup.com/en/content/selection-toys
                  or using the ExtensionWarehouse dialog from within SketchUp 2013 and higher. Navigate to ThomThom's page, and scroll down to SelectionToys
                    Aerilius
                    A lot of the ideas are things that I had found and added myself, others did I integrate now. Sorry that I still haven't finished/published the update because I want to be sure the quality is right.
                    (Some extension stores have longer update cycles, so when I discover an overseen issue, I can't publish a quickfix.)
                    As for searching within the selected entities by attribute, I had thought of that idea, but decided not to get distracted but focus first on the main function of reading/editing attributes. One could certainly add a lot of ideas, but to make a "good" user interface one needs to carefully think about user workflows and how a feature affects the plugin's complexity (of UI and code). I'm not yet sure if search is something that I should better leave for thomthom's Selection Toys.
                    Checking an entity for a "direct" property is on thing, but speed would also be much more affected for attributes, when you consider every entity can have multiple dictionaries, with each mutiple attributes/values. And Christina found that attribute dictionaries can have their own nested attribute dictionaries…
                      jiminy-billy-bob
                      Have you considered browsing through the read/write_default stuff?
                        Aerilius
                        A "registry inspector" is - I believe - not possible with thr API. We can only read if we know the registry key to read.
                          jiminy-billy-bob
                          Ok!
                            Dan Rathbun
                            .. and currently it is very dangerous as (on PC,) the keys written are mixed in among the application's keys.
                            We can only ASK coders to prefix their keys similar to how they should prefix their plugin directories.
                            ex: "Plugin_AE_AttributeInspector"
                              Aerilius
                              I updated the plugin:
                              • definitions (component/group/image definitions)
                              • more data types: points and vectors
                              • optimized column widths
                              • inteloideI Offline
                                inteloide
                                Hello Arilius !
                                Your plugin is very useful for me thanks !
                                Just missing an "update" button, in order to avoid closing an openning the window to refresh and it will be perfect !
                                Thank you !
                                Inteloide
                                Humanity will do a huge step when the IT professionals will understand that computers are tools...
                                  jiminy-billy-bob
                                  +1 👍
                                    jiminy-billy-bob
                                    I found a conflict with TIG's 2DTools.
                                    This plugin adds an attribute dictionnary to the model called "2Dtools", with a key "z" and a value of "0.0" in my case.
                                    This causes the AttributeInspector to not load anything for the model, and the ruby console outputs this:
                                    AE;;AttributeInspector;;Dialog Error for callback 'get_all';
                                    comparison of Length with true failed
                                    C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;505;in `=='
                                    C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;505;in `block (2 levels) in get_attributes'
                                    Blablabla...
                                    (I was able to find the conflicting dictionnary using Eneroth's Attribute Editor)
                                      Dan Rathbun
                                      That is the Trimble SketchUpAPI team's fault. They did not properly override the == method in the Length subclass.
                                      It (the overridden method,) should have an unless clause that invokes super if the argument is not a Numeric subclass.
                                      like:
                                        def ==(arg)
                                          unless arg.is_a?(Numeric)
                                            super
                                          else
                                            # check if arg is within SketchUp's
                                            # tolerance of this Length instance
                                        So any plugin which saves an attribute as a Length will return an error if the test on it is not sufficiently robust ?
                                        So make a test like:
                                        unless object.get_attribute(key, value, nil).class == NilClass ... else next ### end
                                        So now if the key's value is NOT nil you do something...
                                        BUT if it is nil you skip it ###...
                                        But as I read this plugin's code its line #505 uses:
                                        type = (value == true || value == false) ? "Boolean" : value.class.to_s
                                        That is where the failure happens.
                                        The Length is checked for true/false.
                                        If it's recast as something more like:
                                        type = value.class.to_s; type = "Boolean" if type =~ /TrueClass|FalseClass/
                                        Then it'll work with Lengths too...
                                        You could also add a trap for NilClass and perhaps skip that key/value pair ?
                                        ; type = "Nil" if type =~ /NilClass/
                                        OR take it as equivalent to FalseClass ??
                                          Aerilius
                                          Thanks for pointing this out!
                                          I didn't think about that I could get an error when comparing things. I assumed something that doesn't compare would return "false". The ruby way would maybe be to do feature testing:
                                          type = (value.is_a?(Comparable) && (value == true || value == false) ? "Boolean" : value.class.to_s
                                          Which also fails due to SketchUp's bugged API method (Length is a Comparable).
                                          This should be better (and without string comparison). Or shouln't ruby have a "Boolean" super class of which TrueClass and FalseClass are subclasses?
                                          type = (value.is_a?(TrueClass) || value.is_a?(FalseClass)) ? "Boolean" : value.class.to_s
                                          I wanted to list all existing attributes. An attribute can persist with a value "nil" without being deleted/garbage collected.
                                            Dan Rathbun
                                            Every object, of every class inherits a .nil?() instance method (from Object.)
                                            So:
                                            val = thing.get_attribute(key, value, nil)
                                            unless val.nil?
                                              # do something
                                            else
                                              # recover gracefully
                                            • 2 / 3
