    [Plugin] AttributeInspector 1.1.1 – 2014-05-08
    45 Posts 10 Posters 5.9k Views 10 Watching
      Aerilius
      A "registry inspector" is - I believe - not possible with thr API. We can only read if we know the registry key to read.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Ok!
        • Dan RathbunD Offline
          Dan Rathbun
          .. and currently it is very dangerous as (on PC,) the keys written are mixed in among the application's keys.
          We can only ASK coders to prefix their keys similar to how they should prefix their plugin directories.
          ex: "Plugin_AE_AttributeInspector"
          I'm not here much anymore.
            Aerilius
            I updated the plugin:
            • definitions (component/group/image definitions)
            • more data types: points and vectors
            • optimized column widths
            • inteloideI Offline
              inteloide
              Hello Arilius !
              Your plugin is very useful for me thanks !
              Just missing an "update" button, in order to avoid closing an openning the window to refresh and it will be perfect !
              Thank you !
              Inteloide
              Humanity will do a huge step when the IT professionals will understand that computers are tools...
                jiminy-billy-bob
                +1 👍
                  jiminy-billy-bob
                  I found a conflict with TIG's 2DTools.
                  This plugin adds an attribute dictionnary to the model called "2Dtools", with a key "z" and a value of "0.0" in my case.
                  This causes the AttributeInspector to not load anything for the model, and the ruby console outputs this:
                  AE;;AttributeInspector;;Dialog Error for callback 'get_all';
                  comparison of Length with true failed
                  C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;505;in `=='
                  C;/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ae_AttributeInspector/AttributeInspector.rb;505;in `block (2 levels) in get_attributes'
                  Blablabla...
                  (I was able to find the conflicting dictionnary using Eneroth's Attribute Editor)
                    Dan Rathbun
                    That is the Trimble SketchUpAPI team's fault. They did not properly override the == method in the Length subclass.
                    It (the overridden method,) should have an unless clause that invokes super if the argument is not a Numeric subclass.
                    like:
                      def ==(arg)
                        unless arg.is_a?(Numeric)
                          super
                        else
                          # check if arg is within SketchUp's
                          # tolerance of this Length instance
                      So any plugin which saves an attribute as a Length will return an error if the test on it is not sufficiently robust ?
                      So make a test like:
                      unless object.get_attribute(key, value, nil).class == NilClass ... else next ### end
                      So now if the key's value is NOT nil you do something...
                      BUT if it is nil you skip it ###...
                      But as I read this plugin's code its line #505 uses:
                      type = (value == true || value == false) ? "Boolean" : value.class.to_s
                      That is where the failure happens.
                      The Length is checked for true/false.
                      If it's recast as something more like:
                      type = value.class.to_s; type = "Boolean" if type =~ /TrueClass|FalseClass/
                      Then it'll work with Lengths too...
                      You could also add a trap for NilClass and perhaps skip that key/value pair ?
                      ; type = "Nil" if type =~ /NilClass/
                      OR take it as equivalent to FalseClass ??
                        Aerilius
                        Thanks for pointing this out!
                        I didn't think about that I could get an error when comparing things. I assumed something that doesn't compare would return "false". The ruby way would maybe be to do feature testing:
                        type = (value.is_a?(Comparable) && (value == true || value == false) ? "Boolean" : value.class.to_s
                        Which also fails due to SketchUp's bugged API method (Length is a Comparable).
                        This should be better (and without string comparison). Or shouln't ruby have a "Boolean" super class of which TrueClass and FalseClass are subclasses?
                        type = (value.is_a?(TrueClass) || value.is_a?(FalseClass)) ? "Boolean" : value.class.to_s
                        I wanted to list all existing attributes. An attribute can persist with a value "nil" without being deleted/garbage collected.
                          Dan Rathbun
                          Every object, of every class inherits a .nil?() instance method (from Object.)
                          So:
                          val = thing.get_attribute(key, value, nil)
                          unless val.nil?
                            # do something
                          else
                            # recover gracefully
                            Dan Rathbun
                            BTW... you can currently use the triple equal method with Length class, so this will work:
                            true === length_value || false === length_value
                              Dan Rathbun
                              I always wondered why not ?
                              One thing I have done in the past is create a boolean?() query method for Object (or something else like Comparable.
                              Now this is frowned upon, and I never released it, just suggested, or had it in my test scripts.
                              def boolean?()
                                is_a?(TrueClass) || is_a?(FalseClass)
                              end unless method(;boolean?)
                              AND / OR, ... create a Boolean mixin module, and then mix it into only TrueClass and FalseClass. The mixin module may not actually need any additional functionality, at all ?
                              Then the kind_of? (alias is_a?,) methods will return the appropriate true or false using a Boolean class argument, for any, and ALL objects.
                              The === will also work for all objects, which makes case statements work:
                              Boolean === value
                              Whichever one (or both,) ya'll want, would need to be adopted as an API extension, by the community. (And we'd need to convince the Trimble team to add it.)
                              • tt_suT Offline
                                tt_su
                                The Length class is a bit of a special case. It's trying to be a sub-class of Float - but the Ruby API doesn't really let you do this. So there's some hackery in the background to make it work. I'll file an issue to see if we can avoid the argument error.
                                  Dan Rathbun
                                  Thanks TT.
                                  Just returning false would be preferable, instead of raising an ArgumentError (when really TypeError occurs.)
                                  • tt_suT Offline
                                    tt_su
                                    Yea, there's a few annoying inconsistency where the correct error isn't raised.
                                    • 2 / 3
