    Scenes question
    25 Posts 7 Posters 1.4k Views 7 Watching
    • TK0001T Offline
      TK0001
      @ntxdave said:
      I love the concept of this. I do models of car washes. I would like to be able to highlight each piece of equipment so we could discuss it with the client. I have built a model that has each piece of equipment on a separate layer. I can then click on one scene at a time and it then reveals that piece of equipment. Thus you can go from the front to the back of the car was revealing one piece of equipment at a time but it would be neat if I could do something like you are suggesting where I have one scene that is the full car wash and then each of the other scenes having just that piece of equipment highlighted.
      I though of creating some "overlays" that are semitransparent on each scene that covered everything but the piece of equipment I wanted to highlight.
      I also built an animated movie that displayed the scenes one at a time, thus making it look like I was "building" the model but with a movie, I can not really pause it at each scene to discuss it. I want a "presentation" that will allow me to navigate through the scenes one at a time. I have actually tried that as a thread on a couple of occasions but got zero responses.
      I never thought of the ability to control the percentage of visibility for a layer but I could see some really interesting usages for that. Think of this whole concept inside of the 3D PDF as well.
      Dave,
      I think the technique I used here would work well for you, as long as the views are relatively close to the camera. The further you pull away, the more the dark edges jumble up the background "unhighlighted" information. The model I'm working on is of a facility that is rather large, so I want to try to dampen the background stuff as much as possible.
      What I really wanted to do was replicate the view SketchUp gives when you double click on a group, but with transparency in the surrounding information. I'm close. Hopefully I can get there.
        Is there a way to control the edge color of different groups within a model?
        Color edges by Cplassay ?
        • ntxdaveN Offline
          ntxdave
          @tk0001 said:
          Dave,
          Yes, it probably would however, that means all of my groups would have to be duplicated plus there is the camera distance issue. The car wash runs anywhere from 135' to 155' long. Therefore, the lines could be an issue.
          My other point is that everything is centered around presenting in a paper driven environment (which I fully understand since a one of the primary uses is for the builders and etc.). However, today's environment also needs to be a little more multimedia focused as well. As you described about the monitor, we also present our proposed layouts from time to time with touch screen monitors. One of my dreams would be somewhat similar to what you were describing/wanting. It would be really neat if I could bring up one of my models/layouts, double click on a piece of equipment (component/group) and have it highlighted or the rest of the equipment hidden (like double-clicking on a group).
          I have looked at some presentation tools that support 3D models but they do not give me the capability to "cycle through" the various pieces of equipment in my model/layout.
          Guess I am just living in a dream world Wish I was a good enough coder to go off and develop something on my own. πŸ˜’
          Press F1...thank me later
          • TK0001T Offline
            TK0001
            Thanks for the suggestion, Pilou. I gave this a try, and whenever I tried to utilize the program, it switched the colors in the model from "all same" to "by material" and the model looked washed out and impossible to make sense of. I am not educated on the difference between "all same" and "by material" but I'm guessing "all same" is a relatively new functionality and this plugin was built around "by material" being the default. From what I recall in the older versions of SketchUp, there were only two selections for coloring: by material an by layer.
            Regardless, back to the drawing board.
            • TK0001T Offline
              TK0001
              @ntxdave said:
              @tk0001 said:
              Dave,
              Good luck in your pursuit, Dave. Hopefully an adequate solution will be presented in this thread one of these days.
              FYI, to give you some perspective, if you refer to the "Highlighted" image above, the outside dimension of the blue highlighted equipment is about 300'.
              • 2 / 2
