    Building thickness
    24 Posts 9 Posters 1.0k Views 9 Watching
    • tt_suT Offline
      tt_su
      @rudbeckia said:
      A 3d printer will not read just a face in SU even in the faces are closed, like a cube. It does not read the cube as a solid......at least thats what i have been told.
      I've not had that problem. When you have a closed volume, in SketchUp it will say "Solid" in Entity Into then it's good to go for 3d print.
      This was printed from a SketchUp model:
      https://lh3.googleusercontent.com/-8uzkqpEAPfA/T9sv_fQ9W1I/AAAAAAAABWs/p5dSGHFq2wQ/w716-h985-no/Peon.jpg
      https://plus.google.com/u/0/photos/103450081381233788032/albums/5754245713469640065
      I used iMaterialize's services.
        Poor pawn ! πŸ˜‰
          The simple definition of a manifold solid - one that will successfully 3d-print when exported to a compatible file format - is a collection of 'geometry', consisting of just faces and the edges bounding those faces [within a group or a component 'container'].
          Every edge must bound exactly two faces - no fewer and no more.
          So that precludes faceless edges, or edges around holes, forming flaps/shelves etc with therefore one face only, or edges bounding internal partition faces where they would have three or more faces, or edges shared by two otherwise seemingly solid objects - like cubes meeting along one edge - where that edge is shared by four faces.
          It also precludes nested groups/components and any other entities like text and dims.
          Although construction-lines and points [aka guides] within a collection do not compromise its solidity, these are best avoided when sending on for 3d-printing etc...
          • arail1A Offline
            arail1
            You should consider downloading a demo version of Rhino and running the Shell command. I'm assuming you're just printing the outside volume of these buildings, therefore you don't need floors. Shell will do what I think you're looking for.
            • 2 / 2
