    Inserted sketchup file in Laout 2013 shows in wireframe only
    layout
    10 Posts 6 Posters 2.7k Views 6 Watching
    • rishikeshavateR Offline
      rishikeshavate
      Hi friends,
      I inserted a sketchup model in Layout 2013.
      It appear in wireframe mode. When i open "edit in 3D view" in Layout, i can see my style.
      bt when i m out of "edit n 3D view" it shows in wireframe mode,
      I tried change its Style in Layout. But problem is same.
      Can u help,
      • K Offline
        kaas
        @rishikeshavate said:
        Hi friends,
        Can u help,
        Not sure if it's the same problem but 1) is it a complex model (high poly count) and/or 2) are you using a decent gfx card?
        I was changing my noisy cooling on my gfx-card so for one day I had to use the embedded gfx on my cpu. High polycount models in Layout became transparent wireframes in vector and hybrid mode. Only in raster mode the style was displayed correctly.
        Maybe try if a more simple model (some boxes) is displayed correctly with your style?
          There've been several reports of this sort of thing over the past few months. So far it seems that the solutions are:
          1. Change OpenGL settings in SU. This seems to have helped some folks.
          2. Update drivers for the graphics card. This has also helped some folks.
          3. Replace the graphics card with one that is up to the task.
            rishikeshavate
            hi, thanx for ur support.
            It is a low poly model.
            i tried again with basic box model. (attaching the file). But problem is same.
            also i checked with drivers and they are up to date.
              rishikeshavate
              is there any problem with layout 2013?
              i tried the same model in layout 3. and is working fine.
              • JQLJ Offline
                JQL
                This seems to definetely be related to GPU.
                1 - Go to Sketchup
                2 - Window > Preferences
                3 - Open GL > Disable Hardware Acceleration
                If it works, then check this thread so you can reenable hardware acceleration.
                404 Not Found
                (sketchucation.com)
                www.casca.pt
                Visit us on facebook!
                  ArCAD-UK
                  I'm getting this with LO2014 as well on Mac affecting random scenes from the same model all with the same style. Had to switch all the views to raster to ensure textures and images were right in the PDF output. 😞
                    rishikeshavate
                    1 - Go to Sketchup
                    [attachment=0:3q56102l]<!-- ia0 -->Capturar.PNG<!-- ia0 -->[/attachment:3q56102l]
                    404 Not Found
                    (sketchucation.com)
                    i tried this. But dosent worked for me.
                    is there any problem with Layout 2013?
                    Thanx.
                      rafael.paredes
                      hi
                      if you export to DWG it apears in wireframe too? i think the problem is not layout but sketchup and the way it exports certain files
                        rishikeshavate
                        hi friends,
                        The problem which i posted here is not solved. i tried with uninstalling and re installing sketchup 2013 and 2014 both.
                        bt the problem is the same.
                        i used ccleaner to clean registry entries after uninstalling sketchup.
                        bt problem remains same.
                        i installed the same sketchup versions 2013 and 2014 on another machine and it works fine.
                        Whts the problem then? how to clear traces of software?
                        can anybody help me?
