    Apostrophe in Windows user name
    2 Posts 2 Posters 396 Views 2 Watching
    • Al HartA Offline
      Al Hart
      We have a user who put an Apostrophe in her windows user name.
      Thus her app_data folder is:
      C:\Users\SueO'Reilly\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
      (not her real name)
      This was causing our plugin to fail (I can think of lots of reason's why an apostrophe in a path could break plugins which were not planning for it. For instance if you pass the pathname to a DOS or Windows command and enclose it in single quotes.)
      To check for this, we created a new user on our machine with an apostrophe in the user name, and SketchUp 2014 itself could not start properly - with an error about not being able to initiate the sandbox.
      Has any else run into a problem like this?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • sketch3d.deS Offline
        sketch3d.de
        there was a problem with LO13 which crashed during startup in connection with special characters in user names. Which then was fixed with LO of SU13M2.
        Norbert
