    Apostrophe in Windows user name
    2 Posts 2 Posters 417 Views 2 Watching
    • Al HartA
      Al Hart
      We have a user who put an Apostrophe in her windows user name.
      Thus her app_data folder is:
      C:\Users\SueO'Reilly\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
      (not her real name)
      This was causing our plugin to fail (I can think of lots of reason's why an apostrophe in a path could break plugins which were not planning for it. For instance if you pass the pathname to a DOS or Windows command and enclose it in single quotes.)
      To check for this, we created a new user on our machine with an apostrophe in the user name, and SketchUp 2014 itself could not start properly - with an error about not being able to initiate the sandbox.
      Has any else run into a problem like this?
      Al Hart
      IRender nXt from Render Plus
      • sketch3d.deS
        sketch3d.de
        there was a problem with LO13 which crashed during startup in connection with special characters in user names. Which then was fixed with LO of SU13M2.
        Norbert
        With your input, this post could be even better šŸ’—
