Banque d'images 3D
Bonjour,
Je suis passé de SU PRO 2013 à SU 2014 et qu'elle déception, je n'ai que des bugs:
La banque d'images 3D ne s'ouvre pas.
Et il y a plein de plugin pas compatible avec cette version.Quelqu'un à une solution?
Merci -
Hi, please use english here.
If you want you can join the french subforum and use french there. -
If you want you can join the french subforum and use french there.Thank you , how can y join the french subforum please
Sorry about my English -
From Sketchucation's FAQs:
You can view all usergroups via the “Usergroups” link within your User Control Panel. If you would like to join one, proceed by clicking the appropriate button. Not all groups have open access, however. Some may require approval to join, some may be closed and some may even have hidden memberships. If the group is open, you can join it by clicking the appropriate button. If a group requires approval to join you may request to join by clicking the appropriate button. The user group leader will need to approve your request and may ask why you want to join the group. Please do not harass a group leader if they reject your request; they will have their reasons.
Register LoginAdvertisement
