Several Question With Images
hello im new to sketch up
i hope you can answer some of my question im sorry for bad englishscenario 1
how i remove the inner faces in this Box automatically
without using The hide function and deleting it manually one by oneis there a plugin or is there a function in Sketchup?
because i notice Ring function Doesnt connect once there is inner face
Scenario 2
how do i redraw the face automatically without using pencil
but only outside of edge same result in scenario 1is there a plugin or is there a built in function in Sketchup?
thank you !
Remove inner faces by Wikii
Cleanup by Thomthom
For the inverse it will be problematic for the inclined one as you must select something particular before!
Else component dropper by Thomthom can make the trick but you must transform each face selected in group or component before!
face(s) to group by bentleykfrog -
Cleanup by Thomthom
face to group by bentleykfrogthank you for quick reply !
scenario 1 is now solve this is the plugin im looking forscenario 2 still have problem
it does not auto fill the box or do i need to change the setting to rightwhat i want is auto fill the missing Face in drawing skeleton
without Using Pencil Tool so i will not retrace again one by onelike this from object 1 skeleton To Object 2
thank you again for help
Well if the objects are quite simple as you show you can try this one.
Register LoginAdvertisement
