    I need to render a Skp stadium model.
    5 Posts 4 Posters 587 Views 4 Watching
    • F Offline
      Florescu
      Hello!
      I have a computer killing model of a stadium im sketchup. And I need to render it somehow. I chose Artlantis because it's the only program in which I could export the model without crashes.
      Still I have a problem. How can I get a football pitch texture, with stripes, or squares just like many stadiums have?
      I searched all over the internet and did not find examples or ways to do it.
      So if you can help me I will be extremely happy πŸ˜„
      Thanks a lot!
      • FrederikF Offline
        Frederik
        Wonder why you were only able to export to Artlantis...?
        How big is the SKP file...?
        What render apps - apart from Artlantis - have you tried...?
        Cheers
        Kim Frederik
        • F Offline
          Florescu
          well...the skp is 8 mb but the atl file is 1.3 gb. Wanted to export to Lumion because it has a lot of football pitch textures but the program could not load the .dae and the .obj file and when i tried to export from sketchup to .3ds it took me 9 hours to reach 83% and then crashed πŸ˜„
          There are 35k chairs and there are 8500000 polygons.
          computer details Amd phenom II x4 955 BE 3400 mhz, 8 gb RAM and GTX 480.
            matt.gordon320
            Would you be able to post the model at all? If you're not up for sharing it publicly than you can PM me and I'd be happy to have a look. It could be a few things without the model to look at.
            • mikebelluckfM Offline
              mikebelluckf
              With Lumion and large files just break them down and import as separate .skp models. I did this for a gas platform and a processing plant in situ, with LPG tanker and pipes for days - gives you a quicker work flow as well when elements need updating/changing. Good luck. I am currently designing for UEFA events - most probably same pitch (so to speak).
              MIKE BELL
              http://www.mikebell.euΒ  Β +44 7970 646 705
              Event // Exhibition // Experiential // Installation
              Design / Layouts / CAD Plans / Digital Scamps
