    Topo to 3d printer
    4 Posts 3 Posters 281 Views 3 Watching
      Rudbeckia
      Hi SU Folks
      I have some topography in sketchup generated from contour lines. I need to make
      the topography "thicker" (not just a surface) in order to try and send it to a 3d printer
      I thought intersecting the terrain with a solid cube, then possible erasing the cube might work but my computer keeps crashing (its a large site)
      Any ideas would be much appreciated.
        d12dozr
        The second plugin on this page is called Add Terrain Skirt. It takes a surface and adds a skirt down to a flat plane, allowing you to make the model solid for 3D printing.
        Install that, and you're good to go!
        http://goo.gl/f7ooYh
        • cottyC Offline
          cotty
          Joint Push Pull can do it too.
          my SketchUp gallery
            Rudbeckia
            Thanks so much
