    V-ray invisible object reflection
    renderpluginsextensions
    15 Posts 7 Posters 1.7k Views 7 Watching
      tinlenvin
      Hi guys,
      I just start with V-ray for SU and I have this problem.
      I try to render glass for my windows, but the material reflects a sphere (as you can see in attachment). No idea what this sphere is and where it comes from. This sphere does not appear in my sketchup. Only in the reflection of my windows 😞.
      It must be a virtual camera or something.
      Anyone knows how to hide it ?
      Thanks!
      NO SPHERE WANTED
      • andybotA Offline
        andybot
        check your glass material - remove the "refraction layer" if you have one. Looks like a fog color effect.
        • tt_suT Offline
          tt_su
          That blue color, is that material color, or is it the default colour for back-faces. If that is backfaces you might want to look into orienting the faces correctly as they do have a significance for rendering engines as they compute the scene.
            tinlenvin
            Hi guys,
            Thank you for you answers but I forgot to precise I did not apply any vray material on these windows. The glass is the "grey tanslucent glass" from sketchup. I like the blue reflection it makes, and don't want to use a vray glass.
            WHAT THE HELL IS THIS REFLECTED SPHERE ?
            As you can see in attachment, I made a whole facade with a copy of the window, and the sphere appears. Whatever if I zoom in or zoom out, the sphere keeps the same size on the image.
            Also, but that' not the main problem, why can I see two shades of blue-sky reflection for a same material ? One is really blue, and the other one looks less saturated.
            Thanks for the help !
            • andybotA Offline
              andybot
              try disabling "caustics" in your vray options.
              worst comes to worst, upload your scene so someone can take a look at the file itself.
              • BoxB Offline
                I don't know anything about Vray, but is it possible that it is a sky dome or something like that. In twilight for example, setting a hemispherical sky will give a very different result to a spherical sky and sometimes that results in a blackhole like you are seeing.
                  rspierenburg
                  Change you Face Style to Monochrome and then post an image of your sketchup model. As ThomThom alluded to it could be that you have the Translucent Grey Glass material applied to the back (purple) face of the window which when rendering causes all sorts of weird things to happen. The reason I'm suggesting that this might be the problem is because I see that you have other faces that should be reversed (aka all purple faces should be reversed).
                  And as a second note, default Sketchup Translucent Glass Grey wouldn't have any reflection properties as Sketchup doesn't do reflection. So in order to have reflection it would have to be turned into a "Vray Glass" material so to speak.
                  Rob
                  • andybotA Offline
                    andybot
                    @tinlenvin said:
                    Hi guys,
                    rspierenburg is right. Default sketchup material will not have reflection unless you add it in the vray properties. That's why I'm guessing you also have a refraction layer. Is your glass a single plane?
                    • dkendigD Offline
                      dkendig
                      without a scene file, it's impossible to tell
                      Devin Kendig
                      Developer
                      • V Offline
                        valerostudio
                        This takes the award for craziest thing I have seen.
                          rspierenburg
                          A little off topic but..ok. πŸ˜†
                          • V Offline
                            valerostudio
                            How did you not get that joke???
                            • BoxB Offline
                              What joke?
                              • andybotA Offline
                                andybot
                                aww. Matt, I understood the joke - the problem render looks like the big rolling stone IJ runs away from... πŸ˜„
                                • dkendigD Offline
                                  dkendig
                                  I think I may have a solution. Don't mess with the transparency in the refraction layer, unless you have more than one refraction layer. Just leave it black
                                  Devin Kendig
                                  Developer
