    Define length etc.. ?
    layout
    2 Posts 1 Posters 670 Views 1 Watching
      For me it works to get the Line tool and start drawing a line in the desired direction. Let go of the mouse and type 15mm and hit Enter. Or get the Rectangle tool and drag out a rectangle before typing 15mm,15mm Enter. It may be that in your locale you use a , as a decimal point - then you need to use a semi-colon between x and y, as in 15mm;15mm. You can set the units to mm in File>Document SetUp>Units and then omit typing the units. It's all just like SketchUp. Make sure you click and release the mouse button as you set the first point.
        Perfect! I'm glad it works now. Maybe you weren't holding your mouth right before. πŸ˜‰
