    Create a floor plan
    7 Posts 4 Posters 739 Views 4 Watching
    • R
      RicP55
      I want to create a floor plan for a house I plan to build. I have a little experience with Sketchup 8 and I am looking for a good resource for help creating the floor plan.
      Can someone point me in the right direction?
        • cottyC
          cotty
          my SketchUp gallery
          • cottyC
            cotty
            my SketchUp gallery
            • R
              RicP55
              These videos are great for creating a floor plan from an image. I am looking to draft a floor plan from my own ideas for a home.
              Thanks!
              • cottyC
                cotty
                You should have a look at the tape measure tool (creation of construction lines) and the line tool in this case...
                my SketchUp gallery
                • pbacotP
                  Thanks!
                  Then you can just start by drawing the rectangles to scale. Usually begin making the exterior wall line myself. You can just draw lines, but sometimes drawing rectangles and joining them up is faster. Then you you can offset the lines for the walls.
                  People usually group walls, floors, and ceilings separately so that you can assign them to different layers and hide them separately while working. It is common to also group the exterior walls separate from the interior walls.
                  Use the tape measure tool to help in laying out walls and openings as you go.
                  It might be good practice to work on the 2d plan (as it sounds like you are hoping to do) first before you go into modeling the heights.
