    Override material option error
    renderpluginsextensions
    4 Posts 3 Posters 905 Views 3 Watching
      manamem
      hi, I just started learning about vray options effects on the final rendering but when I switch on the override material option the result is a black render. I tried changing the filter colour but the result is the same. Is there anything I'm missing??
      • V Offline
        valerostudio
        Sounds like you have no light in your scene. Is it an interior using emmitters as lights? Is your GI turned off?
          manamem
          Yes its an interior but I have windows in the scene and I have default lights switched on.
          I tried reducing the shutter speed and changing the GI color and number but it still doesnt work.
          I also downloaded a tutorial and tried changing my options to the
          exact same options of the tutorial... Still nothing.
          • andybotA Offline
            andybot
            did you make sure that in your window glass material, you have the option "Can be Overridden" disabled?
