    Sandbox tool (from scratch) don't work
    5 Posts 2 Posters 1.5k Views 2 Watching
    • G Offline
      gepponline77
      Hi!
      I have a problem with sandbox tool.
      Is the fist time I use it.
      I've watched a lot of tutorial but i cannot follow them because i have a problem in one of the initial steps.
      I selcet FROM SCRATCH in the toolbar.
      I click with the mous eon the first point (origin for example)
      Then I move the mouse along an axis and click again with the mouse but nothing happen.
      It seems like it don't acept my mouse clik.
      In the tips bar it continue show me "select the second corner of the sandbox even if i click with the right or left button of the mouse or hit enter, nothing happen.
      Can anyone help me with this issue?
      thank you!
      • gillesG Offline
        gilles
        What do you read in the VCB? If the length in it is longer than the distance between the first point and the second point it will not draw anything.
        • G Offline
          gepponline77
          Ok that is the problem i was working with millimeters scale! thank you!
          But, what is the VCB and how to change the grid step?
          • gillesG Offline
            gilles
            The "Measurements Box", or "Value Control Box (VCB)" in previous versions of SketchUp, is located in the lower-right corner of the SketchUp window, when selecting the tool just type the grid step+ enter.
            • G Offline
              gepponline77
              ....perfect! πŸ˜‰ tank you so much!
