    Banked curves on a slide
    25 Posts 7 Posters 3.3k Views 7 Watching
    • pbacotP Offline
      Cool one Jeff. (Does Rhino do that rendering too?) I imagined this was a water slide that could go on forever. Yes, your shape would accommodate the more desirable high speeds!
      • jeff hammondJ Offline
        jeff hammond
        i want to build the U version a lot bigger now and use it for skateboarding πŸ˜„
        that's actually a display mode which can be used for visually checking surface continuity (or- that's a screenshot. not a rendering)..
        i just used it in this case as it's quick way to show metal.. but you can draw real-time with the surfaces looking like that which will show how changes affect the smoothness via the visual cue of reflections.
        dotdotdot
          tjaschicksal
          Wow, I didn't expect so much replays, thanks for that. I tried curviloft and shapebender/fredoscale.
          They worked both pretty well, so I tried to make a rollercoaster with a corkscrew which looks alot better then all of my other attempts ^^
            jeff hammond
            that looks cool.. glad you picked up some tips in the midst of the off topic stuff. πŸ˜‰
            dotdotdot
            • pbacotP Offline
              Nice job. It's going to be a wild ride!
              Thanks for the note Jeff. Looking forward to seeing a skate park with "THE SLIDE". Call it "Slide Park". Wish I had the time and smarts to learn Rhino. Looks fun.
              • 2 / 2
