    Banked curves on a slide
    25 Posts 7 Posters 4.3k Views 7 Watching
      I will say Moi for a low price than Rhino πŸ˜„
      And if you have just need "image" you can use the demo infinite of Moi without save ! πŸ˜‰
      With this little free plugin you can past your image of the screen at any size (following your memory card) in the Clipboard and then past it in your 2d favorite program! β˜€
      By Michael Gibson
      Past this script inside Moi Menu Options / Scripts
      Here 2560, 2560 but you can put any thing you want ! πŸ˜‰
      script:var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
      Have fun Nurbsing! β˜€
      http://www.polyloop.net/imagehosting/19645d1ca817a94d.jpg
      • jeff hammondJ
        moi isn't bloated enough. I know that's opposite of the sketchup style mantra of keeping things simple but that only goes so far.
        in many regards, feature rich software is way better.. it's just harder to learn or more confusing at first but once you get past that phase, it's a lot better. the key is trying to keep the UI somewhat simple/logical while packing in a lot of functionality and I feel rhino has done a decent job at this. (especially with the mac version.. the latest UI changes have my workspace more simple looking than my sketchup workspace. it can be setup to where basically, the entire screen is a viewport while still having easy access to all function)
        I guess it all depends on what your needs are. and I guess this has gone way off topic but the OP has lots of options to try already (and has disappeared πŸ˜„ )
        • ely862meE
          ely862me
          Most likely he ran out of RAM . πŸ˜†
          Elisei (sketchupper)
          Come and See EliseiDesign
            Surely for a super Pro use. πŸ€“
            • pbacotP
              U-SHAPED? You just have to take the same shape and run Artisan on it.
              • jeff hammondJ
                ha.. yeah, that's one way to go about it.. i was thinking even more of a U..
                if it's berm_ed, you have to go a certain speed or the thing will dump you out.. if it's a U, the 2yr old can take 5 seconds to make it to the bottom following the path in the middle..
                the 8yr old can get a running start and dive into it then ride more of the sidewall down.
                (not trying to sound like some sort of expert playground engineer here πŸ˜† ..just ideas is all)
                • pbacotP
                  Cool one Jeff. (Does Rhino do that rendering too?) I imagined this was a water slide that could go on forever. Yes, your shape would accommodate the more desirable high speeds!
                  • jeff hammondJ
                    i want to build the U version a lot bigger now and use it for skateboarding πŸ˜„
                    that's actually a display mode which can be used for visually checking surface continuity (or- that's a screenshot. not a rendering)..
                    i just used it in this case as it's quick way to show metal.. but you can draw real-time with the surfaces looking like that which will show how changes affect the smoothness via the visual cue of reflections.
                    • T
                      tjaschicksal
                      Wow, I didn't expect so much replays, thanks for that. I tried curviloft and shapebender/fredoscale.
                      They worked both pretty well, so I tried to make a rollercoaster with a corkscrew which looks alot better then all of my other attempts ^^
                      • jeff hammondJ
                        that looks cool.. glad you picked up some tips in the midst of the off topic stuff. πŸ˜‰
                        • pbacotP
                          Nice job. It's going to be a wild ride!
                          Thanks for the note Jeff. Looking forward to seeing a skate park with "THE SLIDE". Call it "Slide Park". Wish I had the time and smarts to learn Rhino. Looks fun.
                          • 2 / 2
