    Things are getting funky
    8 Posts 4 Posters 704 Views 4 Watching
    • T
      tspco
      This morning I started SU8, the first thing I noticed was the style I have used for years as default went poof. So I go to change the style to what I want, and try to save it as default. I got an access denied error. Then I got a message that parametric.rb went poof also. It was not in my plugins folder, so I reinstalled it, things were good. Now after I got things working as they should, another error pops up periodically "0.skb" access denied.
      I am pretty sure this is not necessarily a sketchup thing, but wanted to share this and see if anyone else has seen this behavior.
      In an unrelated area does Sketchup Make do every thing SU8 does? Or is it one of these upgrade and get less features things, that have happened in the past?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • mitcorbM
        mitcorb
        Hi, Ryan:
        Simply do a google(or other)search on "0.skb". You are likely to see quite a bit of discussion on this, including within this forum.
        From my own experience, it seemed to have something to do with accessing files directly from a usb portable drive, rather than having the file resident on the hard drive in either the Sketchup default folder or a user designated alternative folder.
        Maybe this helps?
        • pbacotP
          This reminds me.
          1. I have NEVER been able to save a style. I get "error file cannot be saved" I check permissions, read/write settings for folders etc. but no help. Dave R tried to help me but he was only able to save a style for me. Saving other things seem to work fine. It's just something I learned to do without.
          2. I have preferences set "Create Backup". NEVER seen a .skb file on my disk.
          • T
            tspco
            Just for fun I made a 0.skp,so far so good.
            • jeff hammondJ
              jeff hammond
              @pbacot said:
              1. I have preferences set "Create Backup". NEVER seen a .skb file on my disk.
              that's because you're on mac πŸ˜‰
              the backup files on mac have a tilde in there..
              -- save a file called 'myProject' and you'll have myProject.skp
              -- do something to the file then save it again
              -- you'll now have myProject.skp (which is your most recent save) and myProject~.skp (which is the backup or previous save)
              (which can then lead to myProject~~.skp but things start getting a little silly at that point πŸ˜„ )
              dotdotdot
              • T
                tspco
                Well I spoke to quick, it is still popping up, so is there a cure? I suppose I could uninstall su8, and reinstall.
                I deleted all skb files on my computer, yet this is still popping up, becoming very irritating!!
                • pbacotP
                  or AutosaveAutosaveMyProject~~~~~.skp
                  • jeff hammondJ
                    jeff hammond
                    lol πŸ˜†
                    yeah, that too.
                    dotdotdot
